I would suggest protecting the cooling hose from header heat.
The heat protector suggested by KnappAttack in this thread is what I have used and it has stood up well.
ty4stroke.com
Looking for a Mid pipe heat shield
Looking for a used or new mid pipe heat shield. I got 10,000 miles out of the original but the eyelets finally came out of it. Don’t really want to spend $200 for a new one but…
Turboflash
- Mar 18, 2019
- Southern MN
Yes! I covered that hose on side facing exhaust. Other side not. Remember, that insulation also keeps heat in too. I also covered the chain case side facing muffler, engine oil tank side facing muffler, engine magneto cover side facing muffler, oil hoses to and from engine - side facing muffler. I also fabricated and installed an aluminum heat shield that fits between my header and rear right corner of engine. All to keep exhaust heat off stuff.You don't seem to skip a beat, turboflash.
Yes, two blankets. Anything else I should consider? Covering hoses or heat barrier on chain case. Any other problem areas that need consideration?
I did the backside of the chaincase and the side facing the muffler. Figured it couldn't hurt. The stuff is quite easy to manipulate and if you have a tricky spot wave a heat gun over it and it'll conform to those funky angles and corners
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Ok, well...this will take longer than I thought. Ty for all the tips, I'll get as much done as possible. Better to be on the safe side.
I suppose I'll clean this up and throw a little cover over this hose, make sure the clamps are tight?
Fatchance, yes I've got a heat gun and understand. Ty
Turboflash
- Mar 18, 2019
- Southern MN
Yup. That hose & clamps has been the source of many problems over the years. Definitely take care of it. PIA to work on.Ok, well...this will take longer than I thought. Ty for all the tips, I'll get as much done as possible. Better to be on the safe side.
Doc Harley
- Oct 17, 2016
- Here & there
Last one.... Does the header get installed first, then notch out this shield and slide it into place?
Should the inside of shield get extra heat barrier??
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Looking for a used or new mid pipe heat shield. I got 10,000 miles out of the original but the eyelets finally came out of it. Don’t really want to spend $200 for a new one but…ty4stroke.com
This would be my sled in the photo!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Best to keep as much heat shield as possible. I had cut mine where you have marked. That section gives support to the top area which will help keep it in position.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Make sure to add some heat shield to the "mid pipe" shield to protect valve cover and coil. My heat shield sits higher up on the header and heat started to melt the coil.
LOL!This would be my sled in the photo!
Yes I saved your photo as I used it as an example when I did mine...never took a picture of my install but it looks the same.
Doc Harley
- Oct 17, 2016
- Here & there
I ordered more heat blanket. So I'll give those coil areas an extra look.Make sure to add some heat shield to the "mid pipe" shield to protect valve cover and coil. My heat shield sits higher up on the header and heat started to melt the coil.
Thanks, Tim
The foil heat shield won't cut the heat on the header. You will need this stuff. https://www.amazon.com/gp/aw/d/B00YJERW40?ref=ppx_pt2_mob_b_prod_image
Doc Harley
- Oct 17, 2016
- Here & there
Where is that for?The foil heat shield won't cut the heat on the header. You will need this stuff. https://www.amazon.com/gp/aw/d/B00YJERW40?ref=ppx_pt2_mob_b_prod_image
Doc Harley
- Oct 17, 2016
- Here & there
Hardest part of the whole job for me is the disassembling & reassembling of the Gap ram air. So tedious it's not funny.
If you have any medical condition whatsoever you might want to pass on this mod.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Doesn’t it just pop out ? Installation video I watched just shows it snapping in Didn’t show cutting the hole in the box thoughHardest part of the whole job for me is the disassembling & reassembling of the Gap ram air. So tedious it's not funny.
