STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
HMMM.....
What are the corresponding positions for Cat springs? Did I miss that post?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
EPI has slightly different tangs than the dalton white also. As Knapp pointed out the EPI purple at 1-0 is identical to the dalton white @ 9-1.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I guess I should check the position of the tangs on that Cat green. I thought they were similar to my Dalton b/o but I could be wrong.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I Dan,so you running it at 9-1 ? I was thinking of trying that same spring with my STM 38 I now am running,or maybe with my Dalton 41/35 with my Dalton ramps with Dalton blue/blk primary.Got my white and testing this weekend....installed it today. 9/1.
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-37#post-1467217
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Post 161I guess I should check the position of the tangs on that Cat green. I thought they were similar to my Dalton b/o but I could be wrong.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
You guys are really cranking up the torsion on those Cat springs. I run Cat green at 0-1, same as I did on my turbo Viper with the purple EPI spring.
9-1 is less than 0-1.
Just got a call today from a fellow that had a Winder on the track Dyno. Maybe he'll post. I hope he does, because it confirms what I have found in the field testing a few weeks ago. Its good stuff.
Lighter springs are not doing well to keep a hold on the belt on the big tunes is what I've found.
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Slight highjack...what kind of spring did you run in your Vmax on the tar? I'm assuming it was pretty stout?9-1 is less than 0-1.
KnappAttack
- Feb 19, 2004
- Welch MN
No, actually quite weak. but I didn't run a roller clutch either. Just an old Cat Reverse cam driven. I ran the Cat yellow with helix's around 62-36. You must realize I ran super high RPM and not much torque in a much lighter package than these turbo trail sleds are. The goal is to shift out a drag sled rather quickly and run out of gear well before the finish line and let the RPM carry you. So big differences to what we're dealing with here now.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Nice info,thanks Mike9-1 is less than 0-1.
Fast
- Sep 25, 2018
Did the articat clutch rattle at lower rpm's and does the tapp rattle at all?Just bought and ran a TAPP on my Cat this last weekend, put on 300 miles in the UP (with STM secondary BTW). It's the most incredible clutch ever! I love the Ski-Doo design, it's buttery smooth, almost electric motor like feel. IMHO for anyone who turns it up, this should be required.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
No, I have team for over 2000 miles no rattle! I also run a green spring middle hole on a 46/36 helix ,STM secondary, and the belt does not slip anywhere ,you need more tension on secondary, just saying I know I don’t have a winder but you need mor tension with turbo horse power, it’s sudden,a light spring ,it will pull it right thru and pop goes the belt, run easy and you will have heat, TAPP is the way to go ,I will have one when this one wears out.
dustin
- Dec 24, 2006
- Meadowlands, MN
- 17 sidewinder btx se
Hey DanGot my white and testing this weekend....installed it today. 9/1.
Just curious, what your changing in your primary if anything to run (test) that heavy white cat spring
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
No changes in primary for the first testing of white. But it certainly may need more weight, we'll see.Hey Dan
Dan
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Lighter springs with what helix? I agree heavier with a traditional helix say a 37/35 or 39/35 or straight 35. But a steeper straight or maybe even reverse helix you CAN go to much tension in the secondary. Not saying guys shouldn’t go heavier on the tunes but be careful going to far. Helix angles will effect this spring tension in secondary. By no means questioning Knapp’s knowledge. Helix your using with these heavy springs needs to be mentioned.9-1 is less than 0-1.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
let us no how this works out for u , I tried the purple spring on your tight muskoka trails , didn't like it clutching ran to hot , also tried the black / tan , it ran warmer at slower speeds vs much cooler at faster speeds , I'm now back with the black /orange at 80 degrees , so far its the coolest temp vs the other springs , also less back shift , its a really toss up between the black /tan and the black /orange .No changes in primary for the first testing of white. But it certainly may need more weight, we'll see.
Dan
- 17K
