ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I recall I shimmed my 12 cat primary, it helped alot down low.You have to shim the spider on those clutches. If you don’t they will smoke the belts at low speeds especially coming out of corners and nailing it or hole shot racing.
Dan
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Has anybody shimmed a team primary? Should be same as my cat 1100 clutch, I had to shim for take off.
I was at my local Yamaha dealer last week. One of the mechanics there I have known for many years. A few years ago he went to a Cat dealership before coming back to the Yamaha dealership. We discussed clutch issues and I asked him his thoughts on the Team clutch. He said it is a good clutch, but it's weakness is that it doesn't grip the belt good enough at lower speeds. I remember someone recently posted a picture here showing the bottom portion of sheaves badly burnt/worn. That may be an extreme case, however, is somewhat a common occurrence. He thought maybe it was due to the profile of the weights, without the engagement 'hump' like Yamaha weights have and also Daltons. I tend to agree.Yes, Had it out yesterday on the lake. We all know lake running is not the same as a trail.
On 290 tune, pulling 84.4 G Dalton QA-2 76G weights fully loaded with 1/2" in tip and 1.5" behind that in arms in with Dalton White Bronze in primary. Secondary setup I tried a few combos. Best I found with my 22/41 gearing was White Dalton Cat torsion at 0-1 with 39/35. For trail I think I'd still use a 35 however, it was slightly slower using the 35 but responds better and would be better in snow or trail conditions. Cat 104 belt ran 9000 RPM and slipped to badly up top. Dayco XTX seemed to work well however up top.
Nice quiet clutch setup. That said, Its off today and I'm going back to the rattling bucket of crap Winder clutch and the 8DN. I just don't like the Higher engagement of the Team and I'm not quite sure the performance is where I'd like it to be. Got a trip coming up and going back to what I feel is a faster setup on the Yamaha primary and the 8DN that I feel more comfortable with. I feel I was overgeared with the 22/41 for the Team as well. It liked to slip down low and you could smell belt as it was engaging and moving around from takeoff. Same with my buddies Cat 9000 who was geared at 24/50. Now I see why Cat gears them so low like that.
Crossfire12
- Feb 13, 2017
I have daltons I have this problem, I’m looking into shimming.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Shimming would be good but know that if you shim the Team primary you will also need to machine the spider nut. The cover hits the nut stock for control of full shift, which I don't necessarily care for, and not the sheaves themselves. IMO shimming will not help enough with this low end slippage either. The large bearing post is starting it out in a higher gear also and the reason I'd want to gear down some more for it.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I understand the TAPP to have the most incredible belt squeeze of them all.....Not that I want to drop big bucks on a new clutch but I do wonder how it would perform. So its not just a long lasting route, it may also be a much better performer and belt life extender.
So far so good with the YAM primary/Ultimax/Less offset ......
Dan
Dan
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Dan
You seem pretty interested in that Tapp! I think you should buy it and ask for forgiveness later!
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Just bought and ran a TAPP on my Cat this last weekend, put on 300 miles in the UP (with STM secondary BTW). It's the most incredible clutch ever! I love the Ski-Doo design, it's buttery smooth, almost electric motor like feel. IMHO for anyone who turns it up, this should be required.I understand the TAPP to have the most incredible belt squeeze of them all.....Not that I want to drop big bucks on a new clutch but I do wonder how it would perform. So its not just a long lasting route, it may also be a much better performer and belt life extender.
Dan
Crossfire12
- Feb 13, 2017
Hey I see you have a boat bilge blower on your sled, how does it work?Just bought and ran a TAPP on my Cat this last weekend, put on 300 miles in the UP (with STM secondary BTW). It's the most incredible clutch ever! I love the Ski-Doo design, it's buttery smooth, almost electric motor like feel. IMHO for anyone who turns it up, this should be required.
Tcat100
- Jan 16, 2019
- Chicago
- ZR9000
Time will tell. Limited room on the side panel dictated this design vs the Derale radiator fan I used in my last turbo.
Crossfire12
- Feb 13, 2017
I went with 4 in bottom side belly pan on the 1100, blew at bottom of secondary.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
TAPP is certainly an incredible primary. Been researching it for a few yrs now and 1200 guys love them. Definitely the cadillac of primaries for the 998. Nice to see more guys with 998s are going this route.
Dave told me he sends them out to run with the 8DN in stock YAM secondary. Clickers like the TRAs have are a bonus for us turbo guys.
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Got my white and testing this weekend....installed it today. 9/1.
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-37#post-1467217
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
You guys are really cranking up the torsion on those Cat springs. I run Cat green at 0-1, same as I did on my turbo Viper with the purple EPI spring.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
9-1 is actually 20 degrees lower than 1-0 because the tangs are different.
- 17K
