- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
The alignment bar we sell will not work as the offset from the backside of the primary to the backside of the secondary is different with the TEAM clutch. A primary puller simply makes it a little easier to change out the primary components for some people. Definitely not needed.
- Apr 17, 2003
- Menno, SD
- Menno, SD
TTT
marsh14
How long is that summer price good for?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Marsh, I will run this through the month of May yet.
- Apr 17, 2003
- Menno, SD
- Menno, SD
Srxspec said:I will offer a summer sale on this setup.
FX Nytro TEAM Secondary Conversion Setup:
The kit includes the following parts:
- TEAM Primary Spring
MTX Billet Weights
TEAM Secondary Spring
TEAM Secondary Helix
TEAM Jackshaft with bearing housing
TEAM TSS-04 Clutch
Suggested Retail: $725
Summer Sale Price: $675
I would also recommend adding a primary clutch puller and alignment bar.
Clutch Puller Suggested Retail: $35
Clutch Puller when purchased with TEAM setup: $30
Alignment Bar Suggest Retail: $50
Alignment Bar when purchased with TEAM setup: $45
So if you purchased the TEAM conversion kit, clutch puller, and alignment bar all at one shot it would be $750 total.
Phone: 605-387-2833
Fax: 605-387-2883
Email: Srxspec@Gwtc.net
