snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
I don’t need a lot of penetration, I’m just a trail rider and would like to run woodys megabites 1.75”on a storm track 1.5”. Is it really that close?
I run 1.575” Woody’s Gold Diggers on a 1.25” Ripsaw II. Had track at 1.70” deflection at 20 lbs weight like manual said. Studs tore up the fins on my front heat exchanger. I tightened the track tension up significantly based on the Precision EFI method that many members on here recommend. That video has been posted numerous times in this forum if you search for it. Sorry not on a device able to do that right now.
Edit: here, post no. 3 for the vid: https://ty4stroke.com/threads/studs-hit-heat-exchanger-fins.160313/
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Do you run a woodys series 1575 or a stud that is 1.575” long. I was thinking running the woodys series 1575 on the 1.5 storm. The series 1575 is 1.98” overall lengthI run 1.575” Woody’s Gold Diggers on a 1.25” Ripsaw II. Had track at 1.70” deflection at 20 lbs weight like manual said. Studs tore up the fins on my front heat exchanger. I tightened the track tension up significantly based on the Precision EFI method that many members on here recommend. That video has been posted numerous times in this forum if you search for it. Sorry not on a device able to do that right now.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I run woodys 1575s on my 1" tracksDo you run a woodys series 1575 or a stud that is 1.575” long. I was thinking running the woodys series 1575 on the 1.5 storm. The series 1575 is 1.98” overall length
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Yes it’s the 1575 series. They call it that because after you pull it through the track it has an effective height of 1.575”. When I ordered mine I asked Woody’s the same question.
Turboflash
- Mar 18, 2019
- Southern MN
Track tension video from PEFI:I run 1.575” Woody’s Gold Diggers on a 1.25” Ripsaw II. Had track at 1.70” deflection at 20 lbs weight like manual said. Studs tore up the fins on my front heat exchanger. I tightened the track tension up significantly based on the Precision EFI method that many members on here recommend. That video has been posted numerous times in this forum if you search for it. Sorry not on a device able to do that right now.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Has anyone had any luck welding a rear heat exchanger without taking it out? It is easily accessible.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Imo your are better off to remove the heat exchanger to clean the area to be welded well and have it tig welded in the flat position!!
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Wow that's long. I was wondering if I should go 1.325 on a 1 inch. How many km a year do you put on with those?
RAMSOMAIR
I've done it on the sled and off. This was a front exchanger on a Venture.
DMCTurbo
- Nov 12, 2005
I'm in the North and generally in good snow, lake runs, etc... 2 years on the track/stud combo and no issues, 9000 kms or so, track must be tight! I run megabites, never bent one yet. I also use the biteharder stud sharpener to keep them sharp.Wow that's long. I was wondering if I should go 1.325 on a 1 inch. How many km a year do you put on with those?
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
With shipping taking longer then normal and unsure how long of a wait it would be to get anything from the US i decided to make my own hose protectors!!!
Turboflash
- Mar 18, 2019
- Southern MN
Marc, you have sooo many talents. I sure wished I lived close to you, there's all kinds of things you could do for me! What beer do you like? LOL
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Bring your sled here and we can quarantine in my garage for a month..lolMarc, you have sooo many talents. I sure wished I lived close to you, there's all kinds of things you could do for me! What beer do you like? LOL
you have many expertise that I would benefit from also
Beer fridge is always full except on sundays...lol
Tonne of guys on this site with many talents and knowledge!
I have learnt so much being on ty4stroke over the years and learn everyday!!
Nothing more rewarding then challenging your self and succeeding!
One of my next challenges in the future is to find a 998 motor and build a monster from the bottom up.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Your right about that! Imagine if someone took the time to make service/owners/performance manuals from the info available on this site for each of the yamaha models?!?! Would be worth twice its weight in gold!Bring your sled here and we can quarantine in my garage for a month..lol
Fast
- Sep 25, 2018
Hey maybe they make an srx wrap, lolView attachment 154800
Yes I am going with with design engineering titanium 2 inch wrap
Looking at this dyno sheet it's shows around 1500*f
