Bigblue1
I have waited to see who came up with a better header design. There always seems to be a comprise with after market parts when there does not have to be. BOP does a great job for example. Looking forward to the flow test but I'm convinced already. Great clearance.
How about a stepped header? Can tell where step needs to be by the heat pattern on pipes. Always gave a little more for me. Beautiful work!
Turboflash
- Mar 18, 2019
- Southern MN
Based on what I can see in these photos, tank clearance looks good. Any clearance issue w coolant hose on left side?
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
As you can see in the pic, it's nowhere near the coolant hose on the left side.Based on what I can see in these photos, tank clearance looks good. Any clearance issue w coolant hose on left side?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
sideshowBob
Any timetable on your testing/results?
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
We should have some flow numbers on Monday. Once I review the data I will see how we compare and if there are any changes to make.Any timetable on your testing/results?
What I do know right now is that the stock manifold has a massive restriction, which explains why these headers make so much more power.
Hopefully one of our 3 is worthy.
Mike
sideshowBob
I am very interested in your header as I would still like to be able to select my 300hp tune but make the same power with less boost.
A few things have been removed in this post, thank you for understanding.
sideshowBob
Mike
Any updates or are you shut down because of Manitoba's restrictions right now.
Tcat100
Any update?
SanDale Fabrication
- Jan 14, 2015
- 2017 998 turbo
Sorry for the late response, been very busy!
Our V1 header outflows all the headers by a long shot however it is too close to the tank for my liking. Still lots of clearance but we're not trying to out do anyone here so there's no need to release this one
V2 flows well yet will get expensive with the merge
V3 is the one we are going to release. It flows extremely well and fits perfect. The bullet inside the collector works as a merge and still isn't as costly as the merge collector.
All headers flowed very well, we wanted to be the same or better and we are definitely that! Fitment is what we are shooting for as we want our header to be as hassle free as possible.
We are going to be building our first batch soon and am excited to hear some feedback.
I will post pricing and available dates soon.
Thank you for your patience and I hope you are all staying safe out there!
Mike
Mike
sideshowBob
Any update on this?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Mike
Hey Mike, any progress on getting the first batch out and feedback? Would love to potentially look at getting a new header to replace stock.
