Top Speed Shut Down?
brenpire
Caledon, Ontario
Website
www.repfire.com
Last year my 06 Nytro would occasionally shut down when running full out. No error codes or lights on the dash. Seemed to happen on warmer spring days. Once the machine came to a stop it would start up again and run. Anyone else experience this?
How about a pinched fuel tank vent line?
Checked that as well. The vent line looked ok. Is there a fuel filter in the system somewhere? The issue could be caused by dirt in the filter. That said I did not see a filter.
Two filters in the tank. Sometimes the lines are just long enough to fish them out with a coat hanger and change them through the neck (remove the white collar) but you might have to remove the flange where it enters the tank and tie a string to the hose to give you some slack. People rarely change them or have problems with them but worth a look- maybe those hoses are cracked or pinched.
