FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
1tp said: ↑
Very confident that 110/112 could be achieved in a 1/2 mile on a similar surface.
I don't think a stock viper with muffler and clutching will ever see that speed, even on ice, let alone in 1/2 mile.
FrozenTows4 said: ↑
2014 XF7000 factory stock with 450 miles on it. 86 mph @ 8750rpms.
What were the conditions? I know guys talk about inconsistency but I wouldn't be surprised if conditions people are running them in are playing just as much a part. In addition to guys that like to fib about their speed. ............................High 80's and 90's are the norm on the trail...
Devil Track lake was really hard packed. Barely enough to lube the slides. Temperature was around 15 degrees Fahrenheit. 86mph is fine with me. My gps surprisingly agreed with that number. Like I said, I knew it wasn't a lake racer going in. Nitro would have been more suited for that. Comfort, corner to corner, and fun factor, is what it's all about for me. The XF/Viper 136 fills that slot perfectly.
If I see triple digits, at some point, that's fine. But most of the time we're at 20-40mph. Average speed, for the 3 days, was 25mph. The couple 80-86mph blasts, about 10-15 seconds each, did little for the average rolling speed.
FrozenTows4 said: ↑
ViperMatt
- Jan 8, 2015
- 2015 SR Viper XTX SE
2006 Apex ER
Something kicked in on my XTX SE. I now have just over 2000km on her and it seems to have a little more top end lately, not a lot, but some. I was only seeing 140-145ish for a while, then didn't bother trying for a high speed and concentrated on playing in the deep.
Well on my way back from a powder session the other day I decided to see what she had again and saw a consistent speedo reading of 156km/h and some flashes of 157km/h. This is stock, other than a med windshield. I was laying almost flat on my stomach to stay out of the wind as well.
Not sure I'll ever see 160km/h (100mph) on the speedo, but I was pleasantly surprised to see 156km/h.
And on a side note, my buddy was crossing the lake with me fully pinned on his ski-doo 800 and blew his motor. Good old yamaha had to tow him off the lake.
1tp
- Feb 2, 2014
- Central Wisconsin
- 2015 Viper R-TX LE Clutched and Canned
2014 Viper L-TX SE Clutched
What were the conditions? I know guys talk about inconsistency but I wouldn't be surprised if conditions people are running them in are playing just as much a part. In addition to guys that like to fib about their speed. We all know how much of a difference it makes and you need snow that you can barely compress or ice to hit the c-note. Any clutching that is off, too tight a track and all the other factors will knock off speed off in a hurry. I have squeaked 100 out of it numerous times all stock besides a clutch kit but 95% of the time I don't have the conditions or room to do it. I haven't tried since adding a muffler and more clutching. It's not going to happen with all the snow I've been in. High 80's and 90's are the norm on the trail. Squeaking over 100 is on the rare days I see the right conditions , but it will do it.
1tp
- Feb 2, 2014
- Central Wisconsin
I see no reason why those speeds would not be obtainable seeing how we saw 3 runs of 107. All 3 sleds were still pulling at the end of the run.
vibeline
- Dec 31, 2007
- 2016 ZR7000
I went to a demo ride yesterday. I rode 2 sleds, not sure of all the letters. both sleds were 2015.
1st one was a 129" viper no windshield with fox floats, 85mph flat out would not go any faster. it had 330 miles on it.
2nd one was a 137" viper tall windshield coil over shocks, same stretch of trail 96mph and still climbing, I ran out of trail. it had 390 miles on it.
I want to buy one, but not so impressed by the top speed, I did like the low end torque.
how could the two machines be so very different? and the longer track machine be so much faster.
thanks for the info,
cheers.
cheers.
- Apr 14, 2003
- Hessel, Michigan
cheers.
Don't know why the long track sled is faster.....
I think it's because of track ballooning. Under just the right conditions a ballooning track is faster since its like a dragster tire. 141 will balloon more since longer. Other conditions that ballooning will slow you down and tight track is faster. Just depends.
weasel33
This is around par for the coarse! Inconsistent from sled to sled.I went to a demo ride yesterday. I rode 2 sleds, not sure of all the letters. both sleds were 2015.
cheers.
cheers.
Was the RTX the LE with the deep lug track?
mckay_06
- Mar 23, 2011
- Saskatoon, SK
- 2014 Yamaha Viper XTX
Hit 93 on a near perfect conditions on a lake yesterday with a long stretch. Average though would be 83-85 with pretty much stock other than mbrp and Carlisle Ultramax belt.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
Went out on Saturday down to Constance back, track was hardpack but enough to lube slides, 104 was the magic number, revved right out to 8950, checked shift out and was about 1/4" from top of primary... Swapped out springs from white to pink, same result top end, the pink spring pulled harder bottom end and mid range with my setup. Never got into skid adjustments while out there, could potentially be more that way not sure though.
Dirtbikekid1998
- Mar 3, 2013
- Maine
- 2014 Yamaha Viper LTX SE Hurricane 190hp Turbo.
I have a 7/10th of a mile long stretch of trail on a power line that was just groomed two days ago so it is packed with a little fluff on top. I was able to hit 88 each run I did. A couple I saw 89 but ran out of room. The best I saw was 92 but that was going on a parshally down hill section. This is completely stock 2014 ltx se with 670miles and only the updates and re flash done. I think I could possibly get mid 90s if the stretch was completely straight but in the middle there is a slight curve that I have to slow down for.
MADDOG24
90-92 on normal trail. 95-97 in perfect conditions. All stock ,8jp belt and no studs.
vibeline
- Dec 31, 2007
- 2016 ZR7000
both sleds had 1.250 tracks
Mitch Desorcy
MAX PRO
- May 6, 2014
- Winnipeg Manitoba
- 2014 Yamaha SR Viper LTX SE
Ultamax belt will rob you top speed. I tried one this weekend with proper breakin and it robed me 300 rpm. I run a turbo and could only pull 8400-8500 rpm at shift out. Went back to the 8JP and back to 8800-8900 shift out. Couldn't do any top speed runs that day didn't have proper conditions but 0 to 100 mph was a lot quicker with the 8JP.
