dudester48
- Jan 30, 2015
- warrior
these vipers are so inconsistant
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Familyman has 72.5 grams total weight.
SRXracer
@FAMILYMAN / @Srxspec which turbo kit are you running - 4.5 lb trail or the 6 lb intercooler?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Familyman has the 6 lbs intercooler kit.
- Apr 14, 2003
- Hessel, Michigan
Yup
2015 XTX SE bone stock 87 with 39 miles on it may have had more in it ran out of realestate.
1tp
- Feb 2, 2014
- Central Wisconsin
- 2015 Viper R-TX LE Clutched and Canned
2014 Viper L-TX SE Clutched
Add 3 more to the 100mph club. 2014 and 15 LTX ' s and a 2015 RTX-LE. All 3 are set up the same. Excell, Mbrp and clutched. Speeds were between 103 and 105 in a distance of 3/8 of a mile on ice. Speeds were verified by gps. As a comparison a stock 2015 XRS had 102. Very confident that 110/112 could be achieved in a 1/2 mile on a similar surface.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
2014 XF7000 factory stock with 450 miles on it. 86 mph @ 8750rpms.
Studroes144
- Oct 30, 2013
Did u ever put heavier weights in yours? I know all the 14 7000's I've driven needed heavier weights as they would rev too high
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
As far as I know, it has the stock 57 gram weights. Prior to delivery, I e-mailed copies of all re-calls, and service bulletins, that I was aware of. One of the service bulletins was for the possible over rev situation. Dealer said that all re-calls had been done, but no itemized documentation on the sales receipt as I requested. I purchased 60 gram weights, but did not install. Wanted to get a couple miles on first.Did u ever put heavier weights in yours? I know all the 14 7000's I've driven needed heavier weights as they would rev too high
I expected to hit the rev limiter crossing Devil Track lake last Friday. Nope. 86mph @ 8750rpms. The sled is ready for it's first oil change. I'll pull a weight to see what's really in there. So far, I love this machine. I knew that it wasn't a lake racer going in. I wanted a comfortable trail machine with spirit. And that's exactly what it is.
Studroes144
- Oct 30, 2013
Gotcha, curious to see exactly what weights are in it, the ones I drove would over rev right out of the box so once they got miles and broke in they were worse yet, yours sounds like she'll run real good with some more miles!
sixstringorsnow
- Jan 20, 2014
- Moncton, NB
- 2014 SR Viper LTX SE
My wife's xf 7000 came with 60's in it from factory.
toddszr600
- Oct 31, 2014
- Blue Point, Ontario
In my earlier reply, she fell off at 94 and stayed there, the other day she got to 97 with no issue before I had to shut it down, good long run though, I guess shes getting broke in. We may break 100 yet.
Bone stock 14 ZR7000LXR at 1500 miles on odo, flat field, fairly freshly groomed. All updates done including weights and a trunk full of whatnot
Cheers, Todd
Cheers, Todd
I don't think a stock viper with muffler and clutching will ever see that speed, even on ice, let alone in 1/2 mile.
What were the conditions? I know guys talk about inconsistency but I wouldn't be surprised if conditions people are running them in are playing just as much a part. In addition to guys that like to fib about their speed. We all know how much of a difference it makes and you need snow that you can barely compress or ice to hit the c-note. Any clutching that is off, too tight a track and all the other factors will knock off speed off in a hurry. I have squeaked 100 out of it numerous times all stock besides a clutch kit but 95% of the time I don't have the conditions or room to do it. I haven't tried since adding a muffler and more clutching. It's not going to happen with all the snow I've been in. High 80's and 90's are the norm on the trail. Squeaking over 100 is on the rare days I see the right conditions , but it will do it.
Barney Maclean
- Oct 15, 2014
- ontario
- 2016 Yamaha Viper RTX SE
Riding Southern Ontario yesterday! Trails were pretty fast with a bit of loose snow! Fastest was 143km or 90mph. I Love the pull from start to 120kmph but wish it had more top end!
