Track alignment
Here's the deal.suspension in everything is good but the track needs to go to the right 1/4 inch.the trihub is rubbing on the track nubs.ive tried everything to move the track over.loosen the right side almost all the way and cranked down all the way on the left side the track wont move over at all wth.even tried with a piece of wood to drift it over and track wont go over to the right one bloody bit.whats wrong here .getting to the point of dumping this sled.help please.
Skid in same holes both sides? Links at back clocked same? Trip hub bearings good?
Yup .just cant get skid over at all .getting pissed cause cant ride and wear tri hub wheels.
Again, did you do anything to the skid when it was out?
All I did was change both track adjusters and bolts.only go in one way.
Well I loosened the track off all the way then put the back end of the sled on the ground then pulled the sled to the right and it lined up perfectly.lifted the back end up again and adjusted track tension then tightened idler wheels.fired sled up and it moved back to where it was.whats going on here?only thing I did was change track adjusters and bolts when I had the skid out.skid is in and not cocked on the front shaft.torsion springs are set right.
You can see how much it's out to one side but not worried about the outside wheels it's the trihub that's rubbing on the inner track nubs.only other thing I can think of is when I had the trihub out does it have a left or a right when it goes back in cause I never checked that
Thats a good start for pics. Need Trihub and adjusters. You are looking at the clips to rail outside right?
Was okay last year nothing has change.gonna take it out and ride it like I stole it and maybe something just has to seat itself.i know skid is in right .
Well just got back from a 5 mile somewhat high speed ride and never moved over.just going to ride it this year if it wears out the tri hub and track so be it .don't need this crap in my life right now lol
