Track alignment
How tight or lose is your track. I am of course referring to track tension. If the track is too tight it could act up.
Not the issue at all.thanks
Well turned the trihub around no difference. Tri hub rubbing on inner track nubs .has to move to the right and the adjuster is moving the trihub but it's not moving over if that makes sense.
Some of us went through this back in 14 when the vipers came out. For some reason this skid doesn't lend itself to precision alignment like the old yamahas. I just set mine with equal threads showing on the adjusters and ride. assuming everything else is assembled properly of course. Don't let it ruin your day.
X2 Right I used to do same. 9000mi on that track. New one adjusts easily but I also changed to introvert drivers.
Another thing I do is put a few fingers between the track and slides as i tighten the adjuster and try to feel equal pressure. I know it's not very scientific, but at least it tells me they are close and nothing is drastically wrong.
I hear you as far as getting it perfect but I cant have the tri hub rubbing on the inside track nubs.will wear the track and tri hub .but then again I'm so pissed at this thing right now I don't care lol
Well got the track decently centered and notice tri hub floats cause it moves from side to side between the track nubs.my friends artic cat was rubbing as well.all is good.thanks for all the suggestions
You sure the adjuster stops are on the inside? Why is TriHub floating back and forth? Take a pic of that thing and the adjusters.
Yes on the inside .didn't mean float but moves somewhat cause was rubbing on the track and went for a ride and it had moved over.and wheels were tight
I am no good with descriptions. Need a pic. But if you are happy its all good then ride on.
Too hard to get a picture in there but you can see on my previous pictures the adjusters are on the inside
Yea looking through your pics if bearings are good I cant see anything wrong with TriHub install. Run it!
Going to .just have to get weights dialed in now as running big venom but hitting limiter on hard takeoff.the Joy's of sledding .cheers
Yes gates 40c4133 8jp equivalent
