I used the Yamaha kit.Is quite a bit to it for heat protection.Worth $80 for sure if the heat protection is needed.Sure seems like its not but worth piece of mind I guess.
Ultrafrozen
$95 CDN.
c/w aluminum tunnel closure plate and 5mm rivets, aluminum seat heat shield, large rubber boot seal, 4 or 5 adhesive heat resistant foam backed foil pieces, 4 or 5 adhesive foil strips.
I used supplied instructions and a set pulled from this site. Supplied was a little lacking.
i left all my plastic on and just got a piece of diamond plate havent had any trouble yet
Voda2000
- Nov 15, 2006
- Winnipeg Manitoba
- 2007 Phazer GT 136"
I vote for the factory closure too.
I figure if Yamaha could save a buck and not have to install the extra heat shields they would.
- 47K
