![](/styles/vip.gif)
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
sk-rx1
I have been told that their will be no new traction brackets for the 06's but the ones that fit the 05 RX's with the mono-shock will work on the Apex/Attak sleds.
Rob ER
- Nov 16, 2005
Ordered black ones for my red ER today. I think they will go great with the sled
Rob ER
- Nov 16, 2005
NOS PRO, did you have a problem installing your tunnel stiffener to the floorboard? I got a set and it seems like the rivit holes are right over the heat exchanger
Arctic Express
Rob ER said:NOS PRO, did you have a problem installing your tunnel stiffener to the floorboard? I got a set and it seems like the rivit holes are right over the heat exchanger
That could be a major problem.
![Banghead :o| :o|](/styles/default/xenforo/smilies/banghead.gif)
sk-rx1
Put mine on lsat week. The outside rivets does go through the heate exchanger but outside the coolant channel. I spaced out the left side bracket with stainless fender washers to make up for the plate around the shock adjuster. AS I was finisjing up I realized that I could no longer pull the shock adjuster off, like I would do when I remove the suspension. I guess no one picked that up. Not sure if yuo can disconnect things from insdie or if I will have to dril out rivets when/if I ever emove the sususpension.
apex yooper
I thought we wanted lighter sleds. We keep adding more weight.
- 14K
