super_rash
- Feb 24, 2014
Looks really impressive, dynos on the track, and power is up 30hp vs the 1100T from suzuki, with other parametre being the same... lots of power at 13psi so its looking good.. go see their facebook...
Here:
258HP Yamaha sidewinder Arctic cat
With Turbo Dynamics Ecotrail reflash and TD
Turbo force muffler. Unreal HP and all that at only 12.7psi of boost. We used to need 19psi and a 3inch pipe for that kind of power on the 1100.
129HP at the track...
100% Stock Sidewinder made 106 at the track or 212hp at the motor.
This sidewinder is now well broken in with 90 runs with many at higher power level.
Up to 60 hp difference at the motor (30 at the track with the td ecotrail and td turboforce muffler once boost settles after the spike...
Wow... Spool up is extremely quick with the td turboforce muffler, the sled sounds mental in the dyno room.
Voir la traduction
Here:
Voir la traduction
uprider800
- Mar 18, 2016
- winneconne wi
- Arctic Cat xf 9000
Crazy numbers for eco tune and a muffler. Now once it's snow tested I'm in!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I never realized that only 1/2 the horse power at the track
At 12.7 psi no sure about the fuel on the trails
buyrite01
- Sep 15, 2009
- Indiana
- 2017 Sidewinder
Great work! I'm in already have exhaust on order.
buyrite01
- Sep 15, 2009
- Indiana
- 2017 Sidewinder
Yes 50 percent to track maybe with a great clutch setup you might get 55 percent but not very offen.I never realized that only 1/2 the horse power at the track
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
I suspect this is the case...I believe the yam clutching to be more efficient than the cat (team) clutching and therefore getting more to the track with the same or less..
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
That's why correct clutching Is so important, These belt drive systems are very inefficient.I never realized that only 1/2 the horse power at the track
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
yes..not just the cvt system...parasitic losses all the way through the system....gearbox etc
super_rash
- Feb 24, 2014
I'm freaking out on this motor... starting to be hard to hold out until 2018... but i'm still waiting.. its getting hard...
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Wow that is just 5hp shy of my SC Apex at the track! At least I know I should be able to beat even a tuned SW
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Don't want to rain on the parade here, but something does not add up. When I dynoed my last boosted Apex with Simons, I made 259 at the engine at 12 lbs of boost, then took it off the engine dyno and put it right on his track dyno and it pushed between 148 and 150 to the track at 12 lbs of boost pass after pass.
Hard too imagine a 2000 less RPM, one less cylinder and a bunch more decompressed engine making that same horsepower don't you think. Something doesn't smell right IMO, which is not too surprising with TD.
129 track HP is ok for a turbo trail sled, it's not killer by any means. It's more like 230 maybe 35 at the engine which is a little more realistic.
super_rash
- Feb 24, 2014
they discussed their dyno and why it gave these low track numbers, on a french forum,but i didn't understand all that they pointed out but their dyno reads a lot less then the Dynotech dyno on the track, when compared two same machines... so maybe this is the difference, Turbo Dynamics has a Dynojet 360 for snowmobiles so it seems to be the conversion to track Hp's...
KnappAttack
- Feb 19, 2004
- Welch MN
To think that a 3 cylinder decompressed engine is going to make 258 HP at only 12.7 lbs is just unrealistic IMO. I could see it if it had more compression and spun up there higher.
I'll wait to see where D&D, Hypersports, Hurricane and EVO comes in. Doubt it will be no where near 258 HP at all, and certainly not down at 12.7 lbs.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
LolTo think that a 3 cylinder decompressed engine is going to make 258 HP at only 12.7 lbs is just unrealistic IMO. I could see it if it had more compression and spun up there higher.
Why there is so much hate over TD on forum?
super_rash
- Feb 24, 2014
i don't know, i haven't dealt with them so maybe there is something about them.. but i think its all good, but yes, we must see other dyno numbers, i'm thinking they sure didn't boost the HP's at the track so thats a good sign?
- 7K
