Upgrade with Super Spool
Sledroll
Muskoka , Ontario
Canada
2022 SRX LE
2017 SW LTX LE
I have the Hurricane 240 flash with after market BOV .
If I add the SS upgrade , do I need to do anything else ?
Looking for the easiest , least expensive , corner to corner pick me up .
Anyone done this ?
What is your assessment of the improvement .
I would think you'd need the 3bar upgrade. Maybe not if your staying with the 240 SS tune.
I updated to the 240ss and had to add 3 bar map sensor. I would recommend updating won’t regret it.
Anyone done this ?
May as well bump it to 270 while you are at it
You might not need a 3 bar with under 15 psig with 240 , but see how much the 270 flash is over the ss upgrade. The 270 flash is probably what you are looking for , it's a lot better all the way through.
What are they doing in the SS tune? Wastegate duty-cycle, ignition timing?
I flashed 2 Thundercats this year with the 240ss tune. Both needed and got 3 bar map sensors.
I don't think you'll notice much of a difference in upgrading the tune, except making your pocket lighter.
I notice a difference between the SS and non SS. Actually very noticeable
I had the old tune bundle, now I have the ss, and I didnt notice much differnce, or any difference really.
Hmmmmmm.......who flashed your SS tune upgrade ?
Closed wastegate and no leaking BOV? What else can you do to spool faster? New header? Or heat from fuel and changed ignition timing??
Let me know!
I ran both 270sm and 270ss back to back on my sled and could say by my a$$ dyno that ss pick up faster down low!
