DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
Mine was 2.5 turns out @ 150 miles. I did the same, tightened finger tight and backed off 1/4.
09nytro
This is an Arctic Cat chain case soooooo I would do what they say to do , just because yamaha wanted a manual adjuster in doesn't mean they know everything about this chain case
sk-rx1
And, since any warranty issues will be handled through Yamaha it might be best to do what they say. As has been said before we could use some clearer guidance.
APEX XPRESS
Just called Yamaha service and was told O/M is correct 1/4 turn out after finger tight.
I know you guys are a little paranoid about chain case failures, but this is a little ridiculous. All of you looking at the Arctic Cat manual for a Yamaha sled with a Yamaha warranty. You look at the manual that comes with your sled, you don't look at another manufacture's manual. What's the point?
rough rider
What your saying is i shouldnt use the chain adjustment procedure out of my Rupp sevice manual to adjust my chain?
rough rider said:What your saying is i shouldnt use the chain adjustment procedure out of my Rupp sevice manual to adjust my chain?![]()
LMFAO that's exactly the way I am seeing it. I am thinking about selling all of my Yamaha service manuals and buying all Cat manuals. LOL
Did mine by the manual and dealer said same thing.
And this is not a arctic cat chain case !!!!!! If you read any of the mags or bulletins from yamaha its a yami designed set of gears and chain. as well as different jackshaft so that they could use yami clutches. Im with you fellas go by your manual and if the difference is a1/2 turn in a bolt not gonna be that big of deal anyway. Everyone just chill and quit trying to pick this machine apart. What did you buy it for if thats what you were going to do. That and have facts if your gonna put something out there. From what Ive read sometimes on here some dont. But then again it is the internet and you cant believe everything you read
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
and really if you do what the Yamaha manual shows for adjustment and something does happen we have warranty to help out. I think adjust as Yamaha says and go have a blast on the trails and mountains!
I plan to run the hell out of it and have the time of my life doing it.
Thats a big 10-4 on that. If only we could keep snow around here!!!!!
SRX#756
- Jan 30, 2014
- Grand Rapids, MI
- 2025 SRX Sidewinder Final Edition #756 - 1.5" Ripsaw
2014 SRViper RTX SE - Yamaheaters HID Kit, Powder Pro Skis, SLP Can (Sold to brother)
2002 SXViper - Speedwerx Head, SLP pipes, Drag n Fly Heelclickers, Team Secondary Roller, Boyseen Reeds, 1.5 RipSaw, SRX torque limiter, 2" handlebar riser, rear heat exchanger (in heated storage)
- West Michigan
We've almost got too much snow here in Michigan, if such a thing exists lol We haven't had a thaw in a month.
09nytro
What !!!!!!! To much your crazy !!!!!!!
And we don't want a thaw al lest I don't , it been the best ridding in years here , I'm lovin it !
- Apr 14, 2003
- Hessel, Michigan
Was just in Da UP this weekend and can tell you the only way to get to a submerged sled playing off trail is to crawl.... NOT KIDDING! There is so much snow you aren't able to walk. You get off your sled, prepare to be in up to your waist.
They could use more tho
to make the season last longer
- Status
