09nytro
Maybe
![Dunno :dunno: :dunno:](/styles/default/xenforo/smilies/dunno.gif)
![](/styles/admin.gif)
![](/styles/vip.gif)
Maybe cat set them wrong... it would not surprise me at all...
![](/styles/TYLifeMember.gif)
jlemieu1
- Feb 7, 2005
- Rosemount, MN
- 14 Viper LTX SE, 14 Viper LTX
fuzz said:Nope, the 7000's have the same manual adjuster.Just adjusted mine and tightened 3 turns.
Good to hear they fixed that on the production models of the 7000's. I talked a bit to one of the engineers at the MSP unveil said that Yami would never use Cat's auto version...along with clutch, etc...
Cc440
- Sep 8, 2013
- Rochester, NY
- 2014 viper LTX se
Anyone on the fence about checking this should go ahead and do it. Two vipers in our group. Both needed about 4 turns. Only have 140 miles on mine.
Finger tight then 1/4 turn out. Same as in past.
Biglandrider
- Sep 13, 2013
- Goose Bay, Labrador
- 2015 Viper MTX
I checked the first of two XTX's this weekend. It was about 2 turns out. Quick readjustment, a bit of high temp silicone to seal up the minimal damage to the gasket and away we go. Nothing to it.
Biglandrider said:I checked the first of two XTX's this weekend. It was about 2 turns out. Quick readjustment, a bit of high temp silicone to seal up the minimal damage to the gasket and away we go. Nothing to it.
Could you please add your location in your profile?
![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
chain
Chacked my chain adjustment today on the standard model with 126 miles,3 turns loose.Set it at what the owners manual said,have always set ot finger tight then back it off 1/4 turn.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
checked mine last week, ltx se... was about 2.5 turns out... sled only had 100 km on it... Im located in Ontario Canada
Studroes144
Just curious how much play you guys have in your secondary clutch? Mainly the guys that are tightening your tension bolt 3-4 turns. I plan to do this but I am just waiting until hopefully this coming weekend when I can get my quiet can to put on rather than doing it all and having to put stock muffler back on only to take it off again. My second has maybe a half in of rolling play at the most. Seems like 3 turns loose on the chain tensioner bolt would result in more clutch play than just a half inch but I could be wrong. Like I said it's a half inch of play back and forth at the most before I can spin the track back and forth
Some info in this thread...seems to go against the 1/4 turn.
http://www.ty4stroke.com/viewtopic.php?t=124620
fxnytroxtx
Guest
When installing the chain case cover back on do we use locktite or not?
yamyfreak
I adjusted my LTX and my sons 7000 cat. both have about 220 miles and both needed approximately 3.5 turns to tight and 1/4 turn back.
Adjusted my LTX today with 65 miles on it . Took three turns until finger tight and back 1/4 turn. Was able to get gasket off intact but had already bought a copper gasket. Hope that 1/4 turn is correct but that's what is in the owners manual.
Yamacat21
My dealer sent out a warning! Check your chain adjuster jam nut. His came loose and lost all of his oil through the adjuster bolt. Then it popped out of gear. No real damage done but should be checked.
- Status
