crusen32
- Nov 2, 2014
- Sandy creek ny
- 2013 Yamaha nytro k&n intake,jardine slip on under tunnel exhaust, pc3
hi guys so got stuck today while playing on our property sled was running just as it should. As we were trying to pull it out the belt kept slipping and dliding down into the clutches so we shut the sled off a few different times to close the clutches back up so they werent open any more maybe ran sled for 45-60 seconds shut down then start up did this probably 5-6 times started right back up np then the last time we did it went to start and just cranking furl pump primes as it should gauge comes on no codes im lost what else could cause a no start ?? Thanks in advance ps i cant try anything had to leave it at camp in the woods first time a yammie has left me stranded
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Dumb question maybe! But did you check the kill switch didn't get bumped off. It stumped me the first time.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Maybe fouled plugs starting up and shutting down so often?
crusen32
- Nov 2, 2014
- Sandy creek ny
Yea we checked that we also have an arcticcat with same kill switch so we werent sure which way it was actuslly suppose to be plus fuel pump will only prime if its in the right position i think ik it will crank either way thoDumb question maybe! But did you check the kill switch didn't get bumped off. It stumped me the first time.
crusen32
- Nov 2, 2014
- Sandy creek ny
Ive been doing a little research and thats wht im hoping gonna buy some new plugs in the am and try to start when we get there if no start well throw new plugs in and try again to see wht happensMaybe fouled plugs starting up and shutting down so often?
crusen32
- Nov 2, 2014
- Sandy creek ny
How hard is it to get to plugs on these ik my nytro i can go through the clutch side to change them eithout pulling anything but side panel ??
B.anderson14
- Sep 16, 2017
- Eagle River
- Yamaha viper
Just changed them and way easier to go through exhaust side of you have a can on.
crusen32
- Nov 2, 2014
- Sandy creek ny
Stock exhaust but if need be ill take it off if it can all be done without taking seat and tank off
B.anderson14
- Sep 16, 2017
- Eagle River
- Yamaha viper
It can be done.
B.anderson14
- Sep 16, 2017
- Eagle River
- Yamaha viper
Just a really tight fit
crusen32
- Nov 2, 2014
- Sandy creek ny
Just a standard ratchet and plug socket work or fo u gotta use something specific ?? Thanks
B.anderson14
- Sep 16, 2017
- Eagle River
- Yamaha viper
I used the spark plug wrench that came in the tool bag I got
Hawwwtcoffee
- Oct 9, 2016
- SR Viper
- Muskoka
- www.supertraxmag.com/nats
Exhaust gasket will come apart when you take silencer off. Grab a tube of gasket sealer if you decide to take it off.
crusen32
- Nov 2, 2014
- Sandy creek ny
Sounds good thank u
crusen32
- Nov 2, 2014
- Sandy creek ny
Thanks everyone for the help must of been flooded because as soon as we went to start it today it started right up even being -17f outside back home in the garage to start the thaw down process
