justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Guaranteed!!OMG Fleecer you crack me up! I bet you take Ex Lax the day before riding just to loose a couple pounds!
justinator
- Mar 25, 2007
- Maine
post 51 by cannondale mentions this one for $250, seems to be what we would need
https://www.dasaracing.com/product-p/xx-wpim.htm
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Look at post #49.
500 bucks
dam for that price I’ll just take the dam imperller and shaft out!
Switch over to an electric Davies Craig pump.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Correct. There are 2 different kits by 2 different companies. One is just the impeller, the other a whole pump kit. It seems the dirt guys have been aware of this for a while....post 51 by cannondale mentions this one for $250, seems to be what we would need
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea I guess you could say.....they got the dirt on the WP issues!Correct. There are 2 different kits by 2 different companies. One is just the impeller, the other a whole pump kit. It seems the dirt guys have been aware of this for a while....
I should probably get banned for that one
Fleecer
- Jun 13, 2014
- 2019 SRX
Shhhhhh...don't be handing out my secrets!!
- Apr 14, 2003
- Hessel, Michigan
Have there been failures on non tuned sleds?
Will have to look at flow logic, but curious if the higher hp tunes are exposing the impeller to hotter coolant that fatigues the impeller integrity. If flow direction sends the “hot” exit coolant though pump then this could be possible. If pump sees the chilled return coolant then this theory is not viable.
Yes, 2 of them bone stock have had water pump issues.
Reading the SxS forums the 998 water pump failures appear to be very common and on the engines that have had sustainded 8000+ rpm use...kind of like lake and railbed high speed running.
Something caused those knicks I see on the top of the fins.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I am sure it loosened up on the shaft and began to wobble some before it had completely failed.
- Apr 14, 2003
- Hessel, Michigan
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Did you overheat? What are you going to replace it with?
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
This looks good,and are from dasaracing : One of the weak points in the new Wildcat XX engine is the stock water pump impeller and shaft. The stock impeller is plastic. During normal driving, the plastic water pump impeller can actually separate from the impeller shaft which ceases the flow of coolant throughout the engine (The stock impeller is driven by a pin that will actually break the notch in the plastic impeller). If not caught quickly, this can cause a major failure in the engine.
We have come up with a solution to this problem with our new billet water pump impeller and precision ground 416 stainless steel water pump impeller shaft. Once installed, you will no longer have to worry about the plastic impeller failing and causing potentially thousands of dollars worth of damage to your engine. The new impeller threads onto the stainless shaft - unlike the stock impeller set-up which uses a pin to drive the impeller.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
That part looks like a sweet solution. Listed at $250. Also they only list fitment for the wildcat, is there a reason it wouldn't work on the winder?
- Apr 14, 2003
- Hessel, Michigan
Yes, overheated and didn't turn on the temp light till the bar graph read 238F°
I replaced the whole water pump with a new Arctic Cat Thunder-cat pump and housing (Cheaper than the Yamaha and had it within a couple days)
