- Apr 14, 2003
- Hessel, Michigan
Just an FYI, took me 2 hours to change the whole water pump myself in a small space in my garage. If the spar bracket wouldn't have to be removed...it would have been 15 minutes.
Here is a good tip, I had the sled tipped up towards the right with the handlebar on a milk crate. Lost about a quart of anti-freeze.....that was it.
Was new one a different part# Terry?Just an FYI, took me 2 hours to change the whole water pump myself in a small space in my garage. If the spar bracket wouldn't have to be removed...it would have been 15 minutes.
BTP
- Jan 5, 2018
- Michigan
- 2018 Thundercat, 2019 Thundercat
Speed SXS has a kit for this already. They run it in the wildcat XX
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
There is another company who makes just the impeller also for half that price.
Google. DASA is a very reputable company in the atv/utv community. They know there stuff.
https://www.google.com/search?q=Wil.....69i57j33.17262j0j8&sourceid=chrome&ie=UTF-8
BTP
- Jan 5, 2018
- Michigan
Yes that is the kit I was speaking of.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Anyone have any pictures of the winder impeller? I pulled a nytro pump apart and just curious if it is the same. Impeller is molded onto shaft on Nytro. No way to remove impeller from shaft.
- Apr 14, 2003
- Hessel, Michigan
Yamaha didn't have a water pump in stock at the time, so I got the cat one. AC #3020-300
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I am thankful for knock protection and limp mode.
This past weekend I was riding and started to get my knock protection going off with good fuel, didn't know why. Boost looked good.
I noticed a film on my left side of tunnel below the clutches. Looked around and didn't see any thing leaking.
Went out for a ride the next day and sled went into limp mode and temp was up and amber light on on the dash.
Pulled hood off and found antifreeze everywhere.
Sled was towed in.
Coolant system was pressure tested and coolant was coming out the weep hole on water pump.
When waterpump was removed the impeller had broke in half.
So my impeller had started to come apart gradually and the seal started to weep out antifreeze causing my knock protection to go off and save my engine from blowing up while temp gauge was reading normal.
Then when The impeller broke and temps shot up my limp mode kicked in and saved my engine.
Knock protection and limp mode saved my engine.
Sled was towed in.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Frickin junk
Turboflash
- Mar 18, 2019
- Southern MN
WTH causes stuff like this to happen?!!! Has to be cheap quality impellers from China or India!!
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Unbelievable.. Looking like it’s not only cat quality that needs attention..
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I didn't post this to complain, I posted with my experience so others know what to look for.
I am thankful for the knock protection and limp mode for saving my engine.
If this was a viper or nytro with a add on turbo I would be looking at burnt pistons and block.
- 9K
