Weeping Banjo on turbo?
MyOutdoors
Lempster, NH
2020 Sidewinder Ltx Se
I’ve been putting the miles on the SW and playing with suspension adjustments to get it to my liking. As I was going over everything to see if I had any leaks or loose clamps again, I’ve noticed some weeping coming out of the top banjo fitting on the turbo.
I’ve bleed the coolant a few times and have noticed the overflow bottle go down a few times, but it seems to be steadying out.
No antifreeze in the oil, oil level has been fine all along. Engine temps between 167-174 on 100 mile rides every time. The only thing I’ve noticed was this fitting?
Had same issue with my 2018 zr9000 sno pro, i tightened the fitting up and it still weeped for a short while then sealed up, i kept an eye on it for awhile.
