Albanyco
I bought this sled last year but the carbides are totally shot. What do I need to order for carbides for it? Do I need a set of 4 inch carbides and a set of 2 inch? Sled pushes in corners but I’m not surprised considering there is about nothing left.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
I used the 6 inch carbide Woddys Ace Bar on the inside with the stock 4 inch carbide round bar on the outside. It work pretty good but when the trails warm up and get a little mushy they will push when running hard but when things are frozen up it will be on rails with no push or darting what so ever. I have messed around with ski's and found the Cat ski with the staggered carbide or snow trackers work the best. You will get a bunch of different opinions on this but that's what I found works the best with out buying aftermarket ski's.
sab2022
My question also...
OR should I give up on the turner ski's and invest in that other ski and the associated carbides for that other ski?
example: "Cat ski with the staggered carbide or snow trackers work the best" ....understand Yamaha is going with Stryke ski's this year?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Donate those tuner skies to the garbage man and get some C&A’s or Curve XS.....
Curves are easier to steer, C&A’s are Point and shoot, no push.
TPAY243
- Apr 14, 2013
- Northern Wis
Stryke ski is basically a cat ski on the bottom it uses the same bolt pattern for the wear bars.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Snowstuds carbides 6" and 8" been using this combination for over 30,000 miles.
sab2022
Would C&A, Curves ski's be impacted (helped/harmed) by Electric Power Steering (EPS) install summer 2021/2022??
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Can’t imagine it would affect anything. I’m sure it shouldn’t matter if you have PS
Albanyco
I’d love to pitch the tuner skis, but I’m going to be stuck with them for this season. So do I need to purchase two sets of different lengths, two sets of equal length or what? It’s confusing because the manufacturers list carbides by make and model and so I have no idea what carbides fit what.
the tuners on my 16 lasted 4 rips across a meadow before i removed them and replaced them with mtx skis. i have heard a few guys liking bergstrom's set up for tuner skis.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2 sets, 1 set of each pair.I’d love to pitch the tuner skis, but I’m going to be stuck with them for this season. So do I need to purchase two sets of different lengths, two sets of equal length or what? It’s confusing because the manufacturers list carbides by make and model and so I have no idea what carbides fit what.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
I ran 6 inch on the inside and 4 inch on the outside when I had the tuner skis.
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
I ran 6 and 6 on my attak , still pushed bad unless on hard pack . I suffered through those skis a few years then went back to the stock single and was better . Then got mtx skis on my 12 apex , world of difference in turning and floating on deep snow.
SqueezeER
- Jan 16, 2019
- Northern Ontario
- 2020 Winder Ltx LE
Don't waste your money. Just get new skis.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
If you're going to keep them:
6" square carbide shaper bar inside Woody's Carbide Ace Runner - AY6-8500 -- round 4" carbide on outside Woody's Extender Trail III Flat-Top Carbide Runners - EYV3-8500
- 20K
