Threeman03
- Nov 1, 2015
- Flushing,mi
- 2016 Yamaha sr viper ltx LE
2017 winder Ltx le 137
I’m stock except for I installed a camso storm 150 track. Which had a taller lug track
Which might pull R s down
but I’m
running 84-8500 up top
I would like to be 8850 or so.
What is everyone else running ?
but I’m
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I wouldn't worry about rpm's till you put some miles on.
Threeman03
- Nov 1, 2015
- Flushing,mi
I h
i have 1900 milesI wouldn't worry about rpm's till you put some miles on.
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
shim your primary spring a little bit or pull weight out of your arms
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Bone stock mine turned 9000 RPM with 800 miles on. How many miles do you have on? They pull more RPM with miles.
yammitrip1
- Sep 28, 2017
- Rome ny
he stated 1900 miles about sir
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
9100 to 9250. That was after 1000 miles with an orange TP front spring, glide washers & 911 cover.
XP123
- Dec 25, 2016
- Chautauqua NY
Sorry I thought you had a new sled. 1900 miles is plenty broke in and you should be running near 9000. I would check your primary spring and make sure it's not broken.I h
i have 1900 miles
Threeman03
- Nov 1, 2015
- Flushing,mi
Thanks. Good idea.Sorry I thought you had a new sled. 1900 miles is plenty broke in and you should be running near 9000. I would check your primary spring and make sure it's not broken.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Too high of an rpm, get that down under 9000.
fourload
How accurate are these tachs?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Yep, got a whole new clutch kit.
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
He also said peak RPM. Mine would settle at about 8900 to 9000. Not far off, but at least now i have adjustability.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
9000 sounds right to me. Shagman recommends 9000 in perfect conditions so you don't drop as much when it's sub-par.He also said peak RPM. Mine would settle at about 8900 to 9000. Not far off, but at least now i have adjustability.
- 51K
- 7K
