Ron Ronson
- Dec 12, 2018
- Oswego, ny
- 2017 sidewinder
17 137" roughly 1300 miles on it. I Just removed muffler, right side belly panel and oil tank to fix oil tank leak.
While I'm already this far in is there anything else I should be taking care of?
I'm thinking I'll be deleting roll over valve since I'm right here. Anything maybe inside chaincase or anywhere else that's easily accessible right now?
Thanks and appreciate the input folks.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
rollover valve?
DooZ
- Feb 26, 2007
- Minocqua, WI
- ZR9000RR
Doo 1200
Happy reading...lolrollover valve?
https://ty4stroke.com/threads/getting-rid-of-the-roll-over-valve.151185/
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
Get the screws on the chain tensioner tack welded, they have been known to back out.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
I have my oil tank off to reseal and also chain case apart for inspection. Once i removed the chain adjuster the damn bolts were a little loose holding the chain roller so about 1 minute with the tig welder and i dont have to worry about the bolts coming loose again, its worth it to check.17 137" roughly 1300 miles on it. I Just removed muffler, right side belly panel and oil tank to fix oil tank leak.
Spicoli
- Dec 8, 2016
Turboflash
- Mar 18, 2019
- Southern MN
Might want to check out RockerDan's detailed pictorial and narrative on his Sidewinder build.17 137" roughly 1300 miles on it. I Just removed muffler, right side belly panel and oil tank to fix oil tank leak.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Get er done boys! Good to keep any newcomers abreast of all the things were know.
Dan
Dan
Ron Ronson
- Dec 12, 2018
- Oswego, ny
- 2017 sidewinder
Wellll after a bunch of reading I've discovered even more to do, layed off for the season and no snow so might as well. Upper gear is still tight and nothing out of the ordinary looking. Both screws in tension roller are tight but since im in there and am a welder myself... you guessed it both screws are gettin a tig button. Especially after lookin at all rockerdans stuff lol BTW rockerdan im up in oswego ny so if you run outta stuff to do on your machine stop on by
Ron Ronson
- Dec 12, 2018
- Oswego, ny
- 2017 sidewinder
Well sleds been back together a few days and the damn chaincase is leaking. This things gonna be the death of me. I noticed the cover didn't really mate up to the chaincase that well, the surfaces were so different i could rock the cover on it.
Guess I'll just tear it back apart and piss pound the ol permatex to the chaincase to
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Don't forget to use silicone and place a bead on the inside and outside of the sight glass. They are know to come loose.
Also, be gentle with chaincase cover bolts. They have Loctite on them and it is worth the time to clean the bolts and where they thread into the casting. Many have got too viscous on the re-install and stripped them.
MS
MS
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My damn chaincase is leaking now. Apart she comes again. At least I'll have something to do boxing day.
