- Apr 14, 2003
- Hessel, Michigan
Been meaning to post this and now after installing a clutch kit and checking his offset.....anyone who's offset is not where it should be and you are adding a shim or two on the secondary shaft to get the correct offset from the rear primary sheave to the front secondary sheave, you are also making your belt deflection worse or looser.
If you add washers to the rear of the secondary you will need to add washers to the bolt that holds your secondary on the shaft.
If your offset dimension is too much and you need to remove shims on the back of the secondary, you will probably have a tight belt and you will need to remove washers from the bolt holding the secondary on the shaft.
Secondary adjusters work great in this area
