CaptCaper
- Jan 1, 2007
- Northern N.H.
Smokey said:Would there be anything wrong with wiring it direct to the back of the cigarette plug???? It is already fused.
I don't think so as it doesn't draw much current...If it did it would melt the shield. Think about it..
DONE.... Wired to the back of the cig lighter.
Apex18
I wired mine right to the battery, the helmet only came with the cord, no fuse or anything, is that a bad thing?
Apex18
anyone?
Nice Rumble
If you are wired directly to the battery you should have a fuse in-line. If you have a short you won't have to worry about frying your harness. Just replace the fuse. Cheap insurance. Just pick up an in-line fuse at Radio Shack or harware store and wire it into the hot lead.
w8in4sno
thats exactly what i did....soldered it and used shrink tubing ...works perfect and it left the accessory plug open
Apex18
It sure would have been nice to know this before i put everything back together again. So the most that could happen is the wire could short out if the wire rubbed against metal and my shield would melt, or could the machine catch fire too?
Apex18
and why don't these electric visors come with a fuse already?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
I have seen a cord short and burn anything it is touching , jacket , arm , etc , must be fused.
Direct battery ( fused )is good , you can defrost with engine not running !
The power plug , (Gama & Kimpex ) have an adapter to plug direct into it and then to the shield.
Used one all last year worked perfect ! (2007 rtx )
