hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Swapped a few parts around on a 2011 nytro this morning and it won't start.
Fuel pump is running. Got pressure in line when I take it off the pump.
Got spark on plugs when cranking. Plugs are bone dry...not wet and fouled.
Starts up if I spray starting fluid in air box.
Seems to me the t bodies are not injecting any fuel. Any one else ever have this happen?
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
How about the overflow vent line? Is it pinched?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
What did you swap around?
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Left it sit and 1/2 hour later it fired right up. Chris at Schmidt brothers thinks the injectors were plugged by a film from sitting with no fuel in them. I had pulled the trail tank off several months ago.
herndonp
- Nov 28, 2012
- Freedom,NH
That's great Travis. Run some Seafoam thru the gas tank and that should finish cleaning up the injection system.
Pete
Pete
bmazbnytro
Be careful with starting fluid! It is very dry and almost acts like a cleaner. It will take the oil off of your cylinder walls if you use too much, I prefer to use a squirt can of gas for this process.
- 10K
