Xtx 141 front evol pressures?
mshabaz
need some idea what you guys are running in main and evol. I was able to make my turbo viper front end like butter and take any hit I could find. This sidewinder I can't seem to get right. Im about 190-195 lbs w gear. The rear. All good. Got it to ride nice. But the front. It just seems not smooth. I've tried hi pressures. -too stiff. Low pressures. - no good because then ride height seems too low and bangs the evol pressure to quick. Making that harsh too. About the only thing I haven't tried is equal pressures or lower evol than main. Which I don't think will work anyway. What pressure are u guys running. Thank you
I wish I could help you with the front, but I don't have mine dialed in either. What did you find was working for the rear? The pressures were quite a bit lower than the specs in the manual, so I thought I was going to see some improvement going up in pressure to spec, but it actually got worse. Working on backing it back down, but haven't ridden again.
Rear center for me was 50-110. Rear the most important is to get your ride height set. So pressure doesn't matter. It will be whatever gets you to your ride height preload. Rear ride height would be approx 2-3" drop from full extension measured from rear skid bolt to bottom of skid. Evol pressure back there works great for me at 190psi. Then as I mentioned. I honestly don't know what the main is. I just kept pumping until my sag was correct. Rebound is out 9 clicks from hard. I know a lot of people say more rebound the better on that evol but I started out at 17clicks from full out and had to keep working it down to keep it from doing the pogostick
