jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
141 uncoupled is NOT A TRAIL SLED. It’s off trail sled. Sorry just being honest.
mainedrummer
- Apr 13, 2019
- Up North
- Yamaha Sidewinder
Perhaps it depends upon the trails. Up in the County we have very wide and fast trails and I was never at the back of the pack with my 141".141 uncoupled is NOT A TRAIL SLED. It’s off trail sled. Sorry just being honest.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
The XTX is a very good package with the wrong shocks from the factory. dump the floats and use a good shock package it is an excellent trail sled, as good as an LTX Le with a much better transfer. My XTX handles trails excellent.141 uncoupled is NOT A TRAIL SLED. It’s off trail sled. Sorry just being honest.
Dr. FeeLGooD
That's too bad...where did you see that?
Unless I am missing something..
https://www.hygearsuspension.com/co...kage/products/141-pro-linkage-kit-2015-models
Yup...says it all
I think the 141 can be an excellent trail sled. Plenty of riders like that kind of transfer.
I had considered the above kit, but decided to trade sleds instead.
Really the only beef with my 18 that had floats all around was that it bottomed too easily. It felt like the rear of the rear wasn't rising rate.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
- 2018 Sidewinder xtx
16 viper xtx se SOLD
08 nytro rtx SOLD
- Kirkland Lake
Its sad to do with a new sled but change skis I run curves but have heard others work well. Front shock spring is to weak. Air shocks suck from factory. I love my xtx but it takes some set up for it to work well. The best part of the xtx is when tuned you can get that transfer.
WootTootViper
- Jan 7, 2018
- Illinois
- 2014 Viper MPI turbo, taller gearing, Ulmer clutch and tuning.
I think iv got him talked into spending some money on skis. Which curve ski do you have? Heavier skid spring is in the mail.Its sad to do with a new sled but change skis I run curves but have heard others work well. Front shock spring is to weak. Air shocks suck from factory. I love my xtx but it takes some set up for it to work well. The best part of the xtx is when tuned you can get that transfer.
Ontarioviperxtx
- Oct 2, 2016
- Northern Ontario
08 nytro rtx SOLD
- Kirkland Lake
Curve xs they also have a leading edge that attaches on the ski that I just put on this year. Seems a little better.I think iv got him talked into spending some money on skis. Which curve ski do you have? Heavier skid spring is in the mail.
WootTootViper
- Jan 7, 2018
- Illinois
Okay thanksCurve xs they also have a leading edge that attaches on the ski that I just put on this year. Seems a little better.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Get into some tight turns on hard pack it’s not gonna be excellent.
You need to ride a properly set up 129” or a Poo 121” track machine more often, then you would realize your sleds is far from excellent on most hard trails.
Ditch the cool looking bar risers, long tracks, and monster lugs (which should be illegal cause they ruin trails) for Wisconsin trail riding.
You won’t keep up with a 600cc 121” tracked sled on most wisconsin trails.
Its amazing how many guys I get behind every year on the trails blowing every inch of snow off the corners with monster lug long tracks.
Sweating like pigs at the gas station thinking they are going fast.
Just buy the right sled for the job, not the cool looking long track with big lugs.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
My father bought an xtx and was told it’s the best of both worlds by the dealer. He would like to make it more trail friendly. It is very hard to steer and pushes through corners. Also the minute you touch the throttle the skis are a foot in the air. 90psi up front and 130 in the back. Suspension is stock. Has turbodynamics clutch kit and tune. He would like it to be closer to an LTX. Thanks
I have some of the same problems with my 19 LTX 137 , I tried 4 different skis, trackers and the stiffer spring, made no difference. I wish my front end would lift!
Turboflash
- Mar 18, 2019
- Southern MN
Probably already did this, but did you let limiter straps out? Helped on my 137. Where are your coupler blocks set? Might even want to get rid of them all together. Put rubber hose over shaft if you put it back in.I have some of the same problems with my 19 LTX 137 , I tried 4 different skis, trackers and the stiffer spring, made no difference. I wish my front end would lift!
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Thanks for your help, I have 1280 miles of testing different adjustments on this sled, I've made adjustment's to everything and tried different settings. I'm done spending money and time on it.
mainedrummer
- Apr 13, 2019
- Up North
- Yamaha Sidewinder
Let's see, which crossover sled is best on the trails, hmmmm???
