SledFreak
- Feb 7, 2005
- Ontario. Canada
gsxr said:Most people don't realize the front skis on the xtx can be put on 3 ways. Just shuffle the bushings.
narrow for mtn riding , (sidehilling)
middle for mixed riding , (mixed )
wide for trail riding. (wide and flat )
Makes a huge difference !
How do you make it wide for trail riding?
i had no idea. I'll have a look tonight and see where mine are at. Is it all done with bushings? Is it in the manual?
oops I guess i should slow down when i read!!Just shuffle the bushings
sgilbert
I get narrow and wide, but whats mixed?gsxr said:Most people don't realize the front skis on the xtx can be put on 3 ways. Just shuffle the bushings.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
mixed riding bushing on each side...wide...bushings on outside(id run a thin washer bet. the spindle and mount) and narrow, bushings on inside..
sgilbert
ok, so some are running both spacer outside? leaving none inside?I would think that would be to far to side of ski. I did read about and do the wide/narrow swap, with narrow bushing inside, so this would be considered mixed?
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
The ski will not care , the sled is built this way to swap , the spindle is lots strong.
most crossover / mtn sleds can be changed !!!
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the only concern I have is not the spindle but irregular wear on the spindle bushing..
sgilbert
exactly, but then again, I have simmons which on a floor etc. it loads on inside anywayssj said:the only concern I have is not the spindle but irregular wear on the spindle bushing..
sgilbert
also, barely fit 2 in a trailer now
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
sgilbert said:also, barely fit 2 in a trailer now
oooh....good point Id just have to overlap the skis because I think this is just too good...
gsxr
- Feb 24, 2006
- 2023 SRX
"the only concern I have is not the spindle but irregular wear on the spindle bushing" QUOTE
The sled is made for this , any wear will be the softest material , the Ski , the same as before.
ahicks
Properly torqued there should be no wear at the ski. The sides of the ski clamp down hard on a hollow shaft that runs through the spindle. The bushings in the spindle are the wear point - and these offset setups make a very good case for installing a zerk fitting there....now, or when you have it apart replacing the worn out bushings!
Wouldn't the extreme offset to one side or another contribute to "bump steer" becuase the turning axis of the spindle would not be centerline of the ski and carbide?
Just wondering..
Just wondering..
gsxr
- Feb 24, 2006
- 2023 SRX
Yes but it is Hard to measure bump steer on a slippery surface.
On dry , pavement etc , yes .
