gormleyflyer2002
well, yes....but
I would say that yes you could install these while your sled sits sheltered from the wind in a trailer. Finding the required wires to hook into is the biggest challenge for someone that hasn't installed one before. (me) If you have that info beforehand or go locate the wires on your sled beforehand then your golden.
Rocks instructions have pretty detailed instructions for Apex and RX 1 as far as the best location to find the yellow/red and blue/white wire. I installed on my 08 Nytro, it was a late night friday evening rush job before heading out for the ride on Saturday morning.
Bring some wire and box of misc wire connectors, (red blue size)I needed to extend the ground wire on mine.......the top side of Nytro is all plastic and composite.
Swiss Sledder said:gormleyflyer2002, how long did it take you to install? Could you install these while you sled sat in a trailer?
apex*snowman
- Dec 28, 2008
I need a set up for my 2006 apex, let me know what I need to do to get rid of the cold hands.
dmsrx700
I put the 07 hooked bars on my 03 RX1 and while I love the riding position my hands were freezing. Thought I had the same thing going on as everyone else. I was going to put the old reostat off a 97 02 Vmax on and wire it to a switched 12 volt source so I wouldn't take any chances on killing the handwarmwer curcuit in the Ecu. I would have had to put a warmer in the circuit or wire a diode in to keep the check engine light out too. Well as it turned out, I used gauntlets yesterday with my windstopper fleece gloves. Without having the thick gloves on and the gauntlets stopping the wind the bars worked great, just like the old days of the Vmax. Bars get too hot to keep on high, thumb warmer too. Ran most of the time with them almost off. With the fact that the Ecu doesn't supply any power until 4000 rpm and full power above 6000, shuts the power off under braking, wearing thick gloves to try and stop the wind I was heading in the wrong direction. I really don't like the looks of the gauntlets but they didn't bother me while riding, plus I really don't want to alter the wiring on my sled. The ones I used were borrowed so I am going to order some from powermadd that go over the handguards so I have more room for the brake lever and throttle. The temperature was 17 deg. while we were out which isn't too cold but since I rode with the warmers turned all the way down I don't thing colder temps are going to be a problem.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
KnappAttack said:Rock, So if I wanted to put my 07 bars back on my 07 and use the grips all the way to the end of the hook I understand this would allow me to do that.
However as I read it, You only have two options with this setup. A switch that allows the grips to be smoking hot, or the factory setup which is crap. Why can't you control the heat with a separate rheostat like the SRX had to control the warmers? I want to control my 07 Attak GT with a separate rheostat, and allow the toggle on the left bar to control the shock all the time with no codes. Is this possible, or should I just stick to the ROCKERDAN 06 bars on my 07? I sure would like to run the heat all the way down the hook, but I want it adjustable with the rheostat.
Hi Mike.
Good question!
You actually have the exact same options you had before, PLUS a full heat option, all controlled from the existing factory bar controls!
I have the updated '06/07 bars with heat to the ends of the hooks myself.
Love the heated hooks!
Usually I get them warmed up, then one of the factory settings will usually keep them warm enough after that(Factory high, or near high), all controlled from the existing factory bar switch.
If it is REALLY cold, will go back to FULL HEAT mode again with the handlebar controls.
No need to add a rheostat at all.
The single biggest problem with a rheostat is that they waste power you don't have available and can't afford to waste!
The method the factory uses is near 100% efficient, although not very effective!
The FULL HEAT mode is also almost 100% efficient, so in ANY mode with the Warm Hands Controller, you are wasting almost NO power, it is going where it needs to, To your grips!
ANY power you waste is taken from your Magneto, and if your magneto can't keep up, it is taken FROM your battery, and will slowly run your battery down.
Unfortunately, you cannot afford to waste power on these sleds.
The Mode Switch simply tells to the contoller to use FULL HEAT mode OR OFF, when you set your handlebar controls to "off".
The only time you are likely to even use the MODE switch, is in late sprng riding, when you really DO want your warmers totally off!
The rest of the season, just use the one bar setting, it doesn't put out much at all, and is almost off!
Funny, this is sooooo much easier to use, than explain in words! lol
You guys that have them, chime in and maybe someone will come up with a GREAT explanation!
Hope this helps!
Rock
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
dmsrx700 said:I put the 07 hooked bars on my 03 RX1...
Please read the first page of this thread.
This thread is SPECIFICALLY about the Warm Hands Controller, your input is greatly appreciated here, just not in this specific thread.
Do a search, there are plenty of threads on the handwarmer issue.
It will keep you busy for weeks...
Tnx!
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
yamadoo said:Rock,
I am confused some times you say 'turn down" some times change mode. In simple terms are these adjustable while on from the bar toggle controller - I think so but like Knappattack I wonder.
Thanks Yamadoo
Hhahahha! Even that kind of help can be great dude!
Yes, they are all controlled at the bars, with the possible exception of very warm spring riding when you truly want your bars 100% off.
Then you set the mode switch to off, and when you turn the warmers off from the controls, they really are 100% off.
See my prior reply to Mike also.
Rock
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Want to get the wire colors nailed down for you guys.
Am in need of the PDF version of the Nytro & Phazer service manuals.
If anyone has access to these, please PM me the links or email me them please!
That way, I can give very detailed instructions for each sled!
Thanks!
Thanks!
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
apex*snowman said:I need a set up for my 2006 apex, let me know what I need to do to get rid of the cold hands.
Hey snowman!
Just send your amount by paypal.
Instructions are near the bottom of the first page.
The Intro ends Friday, would get it going if you want one at that price.
Also, orders are flled on a first come/first served basis, as you wait, you get later on delivery.
Hopes this helps!
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
2008 FX Nytro Service Manualrockmeister said:Want to get the wire colors nailed down for you guys. Am in need of the PDF version of the Nytro & Phazer service manuals. If anyone has access to these, please PM me the links or email me them please!
xator
- Jan 5, 2009
On a 09 nytro, while running, do the warmer get full 12v, or it's still pulse width modulated a lil below 12v?
skidooboy
not to beat a dead horse but to clarify, the warm hands controller allows the heaters more power, and can be controled up or down with the current bar controler on the sled from low to high (1-10 settings on the nytro) albiet quite a bit warmer???
if you want them off, or a very lower setting you turn off the warm hands switch off and you have the current warmer set up for the factory???
correct???
ski
correct???
ski
Gibby
- Jan 28, 2005
- Jackson, Michigan
- www.fitzgibbonstruck.com
the factory switch will work as it always did, except there will be no off, when the factory switch is off rocks black box will turn on and put full power to hand warmers, so when they get hot you can turn the factory switch back on and it will work as it did before rocks black box, if you want off to be off you have to flip the switch that comes with the black box. hope this helps
gormleyflyer2002
Ski.....you can not in theory adjust the temp or output from the warm hands controller itself. Use your OEM switch like normal to both systems. The controller only provides a high heat setting....(the part Yamaha forgot)...seems odd I suppose but believe me they work well in practise and is no diffeent than stock when riding.
On a typical day you will adjust the temp range depending on where you are riding...morning, the bush, rail line or on the lake.........think of the controller as something that gives you that high or #10 setting that Yamaha couldn't. ....just adds another bar on the dash in theory.....off = hot.
Yesterday was the coldest day of the season so far, it was -21'C when we started.......12 hr day, all with warm hands.
I used this higher setting more when starting after trail breaks or chow.....with thin gloves they got to hot but I could manage with the OEM heat.
Fasttoys
sent you a pm
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
For all of you sending Rock a PM he might not get right back hes still in MI riding. He will get back to you A.S.A.P.
- 34K
