CaptCaper
- Jan 1, 2007
- Northern N.H.
Hi Capt,
We will find out!
PMing you my number, will have you do some tests.
Let's get you going!
Rockmeister
Thanks for your help Friday.... look forward to getting some hot hands again.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
- www.yamaheater.com
- 2007 Attak - LOVE my sled!!!
You are welcome Capt!
Will get you going!
Rockmeister
Will get you going!
Rockmeister
Sledtastik
Is this still available?
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
They sure are!
Can order at www.rocztoyz.com
Scroll down the page.
You will like having Instant Warm Hands on COmmand!
Will get you going.
Rockmeister : )
Will get you going.
Rockmeister : )
Hendo85
So this is what I need for warm hands? Not new hand warmers eh?
ApexGT06Canuck
- Jan 25, 2022
- Whitby, Ontario
- 2006 Yamaha Apex GT
Looking to order a set for my 2006 Apex GT
I read that thumb warmers are increased with the regular yamaboost. Do I require the thumb boost as well?
Wanting to submit my order, with express shipping to Canada.
I attached screenshots for the two selections I'm stuck between.
Is there still a $10 discount for TY members I read in an earlier post?
Thanks in advance for all the info!
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Yes, mention that you are a TY VIP member & your TY username when you order.Looking to order a set for my 2006 Apex GT
You want the P&P with Boost + ThumbBooster Combo.
Just make sure you tell us what sled & year this is for.
Will get you going!
RockMeister
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Correct, you simply plug them in & you will have Instant Warm Hands on command.So this is what I need for warm hands? Not new hand warmers eh?
Using your existing controls, grips, & display.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Hey rock, getting ready to install my hand a thumb kit for my sidewinder I got at big east this year. Wondered if you had any pics of where these modules mount.
Rockmeister
TY Advertiser
- Feb 7, 2007
- NE Indiana
Hey Dude!
I zipty-ed mine under the harness on the bars.
Send me a text to the number on your instructions & will text you a pic.
Rock
Rock
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Will do. In morning. Don’t wanna bug you at night.Hey Dude!
Rock
NLP_SLED_GUY
- Sep 14, 2021
- Northern Lower Michigan
- 2019 SkiDoo GT-L 600R
2005 RS Rage
2003 RX1
1980 Arctic Cat Panther
Does the Yamaheater tame the very stupid 03 RX1 heaters? Having to constantly reset them is ridculous.
targabill
Is there a wiring diagram for this, it was in the Nytro I bought and some wires pulled out and would like to fix.. It has one box with Rocztoyz.com, rock solid quality written on it, not sure if thats the yamaheater or the booster you mention..YamaHeater Booster Install Instructions
Remove appropriate body panels & locate the following connectors:
2 output connectors from your YamaHeater (Orange & Black wires)
Brake connector (Blue/Red & Green wires)
Your YamaHeater Booster installs BETWEEN your existing YamaHeater & your grips.
1) Unplug the grips from your YamaHeater. (Grips have 2 small Black wires)
2) Plug both grips into output connectors with Orange & Black wires from Booster.
3) Plug input connector from Booster (Yellow & Black wires) into one of the output connectors from your YamaHeater (Orange & black wires).
4) Unplug brake connector with Blue/Red & Green wires & plug power connector from Booster with Blue & Green wires into open connectors from brake. (This connects power)
5) Install Black Ground wire with ring terminal under appropriate bolt for ground.
6) If you did not do so prior, change SIG fuse in sled fuse box (Small Black box on right side of sled near reverse mechanism), to blue 15A fuse provided.
Test for grips warming with sled running and in YamaHeater High Heat setting (RED LED, Zero Bars on display).
Allow sled to idle for a few minutes & verify grips are getting nice and WARM!
(Your grips should get SERIOUSLY WARM!)
As noted prior, the YamaHeater Booster will make ALL your heat settings warmer, including the YamaHeater High Heat setting (RED LED).
Mounting:
As it is a power conversion device, your Booster will get warm in operation, keep in mind to allow air flow around Booster.
The Booster Case is a shielded metal case that Cannot touch anything metal on your sled.
Make sure when you install the Booster, the case is isolated from any metal, including ground.
Let us know how it goes!
Rock
PS As always, can Call or PM/email me with your phone number & I will call you right back.
You can always contact Rock Direct, he is great at helping on his products.Is there a wiring diagram for this, it was in the Nytro I bought and some wires pulled out and would like to fix.. It has one box with Rocztoyz.com, rock solid quality written on it, not sure if thats the yamaheater or the booster you mention..
RobX-1
- Coldwater, OH
- 32K
- 148K
