RobX-1
- Coldwater, OH
Wonder if tighter bearing fit has anything to do with why it's quieter?
Lakercr did the same thing and went to the tighter clearance bearing at the same time, he thought it was the bearing that had changed things and quieted the clutch, but I tested the bearing on a stock shaft and it did nothing for noise, so the difference is the spline tightness then in the 1049 shaft, but didn't the Nytro also rattle the clutch? As far as I can remember all the three cylinders rattled the primary badly. Oh well, glad it's working for you. Funny Yamaha couldn't figure this out....
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Well....KnappAttack tried the (KML) bearing suggested. And KnappAttack's comment was it didn't help. My bearing got pulled from Amazon, I'm not even sure its a True Timkin. Haha, food for thought, eh? I'd stick with the shaft being of a tighter tolerance, as other claims."Timken (Japan) normal" I assume is bearing. Factory bearing has C3 fit due to press fit and high heat. Wonder if tighter bearing fit has anything to do with why it's quieter?
To be 100% honest , I was going to pull my old bearing out of my old housing and use that, but if it didn't work, I'd be playing way too many games of "hide the sausage"
In the end....its just clutch noise?!?! Its not the cure for cancer.
Turboflash, Imagine me Actually following someone's advice. Haha.
Let's be honest, I didn't fully trust him. And that is primarily why I kept my snub shaft, etc. Intact
Turboflash
- Mar 18, 2019
- Southern MN
LOL. Yeah, you're not famous for following advice!Well....KnappAttack tried the (KML) bearing suggested. And KnappAttack's comment was it didn't help. My bearing got pulled from Amazon, I'm not even sure its a True Timkin. Haha, food for thought, eh? I'd stick with the shaft being of a tighter tolerance, as other claims.
Doc Harley
- Oct 17, 2016
- Here & there
I'm sorry bud. Perhaps I grew up on the wrong side of town. Lol. besides, I've read most of the groups theories and experiences including yours from back in the day. Never could fix it with simple bearing change. That coupled with Tapp targeting the splines, as a possible fix, it became a no-brainer.
Doc Harley
- Oct 17, 2016
- Here & there
Clearing the air...C3 is considered "normal"
So the bearing I used was to spec. No different than the factory clearance.
Turboflash
- Mar 18, 2019
- Southern MN
Yes, normal extra clearance.Clearing the air...C3 is considered "normal"
Doc Harley
- Oct 17, 2016
- Here & there
Yes, spec'd exactly as the factory bearing C3 rating "normal" clearance.Yes, normal extra clearance.
I read up on this yesterday. The C-Class bearing has five variants to it, with C3 being a "normal" clearance bearing, or the most common. C4 and 5 are extra clearance bearings and C 1 and 2 are tighter clearance bearings.
Doc Harley
- Oct 17, 2016
- Here & there
Nitro shaft with factory original bearing (4200 miles)
I did this mostly to prove to myself, the nitro snub shaft to be quieter then the factory shaft.
Please note; I'm posting this for people who want to fix the problem not to the people who want to ridicule everything they've never tried.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
For those of us that attended too many Rock Concerts I find this to be not a problem.. What noise ? Can’t hear nothing…. Lol….
Doc Harley
- Oct 17, 2016
- Here & there
Simplespeed, all these years and it never bothered me. Then the magical silent seal thingamabob came out. I'll say, for $80 it peaked my curiosity, only to be a bust and completely disappointed. Especially after it worked for the first 5 10 minutes.
Another member must have heard my cries and sent me a PM on how to fix the clutch noise, and I bit on it.
Seems as though the fix has met with skepticism by a few members. And I thought it best to put the old bearing & nitro shaft in there and let the chips fall where they may.
I need to get some hard miles on it to verify it 100%.
Predictions on an early cold & wet season has me getting everything ready, sooner than the norm.
Simplespeed
- Jan 8, 2022
Ya I hear you on a product that turns out to be a bust …. That’s disappointing… I was just making light of this condition as I have on many other design flaws realizing we don’t live in that perfect world …Simplespeed, all these years and it never bothered me. Then the magical silent seal thingamabob came out. I'll say, for $80 it peaked my curiosity, only to be a bust and completely disappointed. Especially after it worked for the first 5 10 minutes.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
I'm convinced Yamaha knew how to fix the rattle but intentionally wanted some play in the stub shaft fit. I suspect it helps dissipate some torque spike or something like that. But I'm probably giving them too much credit. Could be they made too many in the first batch and didn't want to take the scrap.
Doc Harley
- Oct 17, 2016
- Here & there
Thought you were in jail?!?! Anyway, IDK?? Not sure if the harmonics/distortion are good for the clutches. Must be a reason Tapp tried to offer an inexpensive cure. I'll roll with it and see how things go.I'm convinced Yamaha knew how to fix the rattle but intentionally wanted some play in the stub shaft fit. I suspect it helps dissipate some torque spike or something like that. But I'm probably giving them too much credit. Could be they made too many in the first batch and didn't want to take the scrap.
pdiddy
- Oct 12, 2004
- Southern Maine
I'm not that pdiddy. If the real one had a snowmobile he'd have something to occupy his every waking moments!
Doc Harley
- Oct 17, 2016
- Here & there
Its with great sadness that I report back my findings....it took a while due to two seasons of low miles, my clutch noise (typical) has finally returned.
Back to the drawing board! Haha
- 11K
