rx1 fern
so does this mean you are keeping your zx2
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
or are you selling it for how much. Maxdlx
Need for Speed 2
Sending it back to Boivon for a full refund. Pretty good guys considering I may have created the problem
06vectorgt
Would still like to know why Millinocket Rocket 1's is soft if these are all supposed to be real stiff!
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
Jeff how much for the returned skid. Maxdlx
06vectorgt said:kinger said:Jeff, what about 06vectorGT's comments on the one he had installed above? Seems that one wont collapse either and thats a properly set up unit??
My concern is why Millinocket Rocket 1 is soft and everybody else is very stiff.
Jeff please explain how this can be - some of us are very nervous about this.
Don't get me wrong... like I said- maybe I'm not used to having all that travel like the pro-action(didn't have). Ya-- it felt soft, but it felt NICE! Gotta try it out before I get too worried
Or maybe I shoulda said smooth.... it's definitely a much smoother stroke
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
I have enought snow to ride, but haven't finished off the work on my turbo sled yet, maybe by the end of next week. I'll post when I get to ride it.
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
too stiff
I finally put the zx2 in my 05. I installed without the track just to make sure everything lined up. It fits fine and will travel without much effort. This may change with the track on but I don't think it will have that much effect. I am thinking those who cannot get it to move may either have the wrong plates or did something wrong. The mounting hole for the mono suspension is about an inch lower and forward. Maybe people are trying to use the same hole which the mono mounts through, the one used to position the plate for the rivets? Not sure but mine seems to work fine.
06vectorgt
Re: too stiff
twiz - I will be very interested on how the system works once the track is on, as you can see in my install pics on page 2 the mounting holes are where they are supposed to be and my sled feels rock hard.
Excell Motor Sports installed mine and did every thing by the book. They are a dealer for ADB and have installed their fair share of Experts X's - Aaron really knows what he is doing so I am sure my situation is not an install issue at all.
twiz28 said:I finally put the zx2 in my 05. I installed without the track just to make sure everything lined up. It fits fine and will travel without much effort. This may change with the track on but I don't think it will have that much effect. I am thinking those who cannot get it to move may either have the wrong plates or did something wrong. The mounting hole for the mono suspension is about an inch lower and forward. Maybe people are trying to use the same hole which the mono mounts through, the one used to position the plate for the rivets? Not sure but mine seems to work fine.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
06vectorgt, have you tried putting say a 2X4 (to simulate bumpy terrain) under the track and seeing if the suspension feels softer/smoother. You could try it at different areas like under the front arm or rear arm.
My suspension still isn't installed yet and was concerned earlier that it was too stiff as well. I was standing on the rear arm to try and collapse the rear arm and shocks, but it would only move about 2-3 inches, with me being at 260 lbs. After Jeff from ADB mentioned that everything works in conjunction with each other (front and rear arm), I ended up attaching the mount plates to the suspension (still not in sled) and tried the same thing. It certainly felt a lot smoother, softer and collapsed the suspension a bit more.
I think that once you get your sled out on the snow, you'll see that you were getting worried about nothing. Forget the snow, just take it out on your (and maybe your neighbour's) lawn and find out now. Run over a few garden gnomes to simulate the bumps.
06vectorgt
Grimm said:06vectorgt, have you tried putting say a 2X4 (to simulate bumpy terrain) under the track and seeing if the suspension feels softer/smoother. You could try it at different areas like under the front arm or rear arm.
I think that once you get your sled out on the snow, you'll see that you were getting worried about nothing. Forget the snow, just take it out on your (and maybe your neighbour's) lawn and find out now. Run over a few garden gnomes to simulate the bumps.![]()
Hi Grimm - I will try the 2x4 trick just for grins, my friend told me that when he had his Xpert installed it took about a days ride to losen up (they are using the same shocks in ZX2). I'm surprised the Expert folks haven't chimed in on this if this is the case.
ADB is a reputable company and I'm not overly worried about this being corrected (if need be). Waiting for snow to give her the acid test and at which point I will know what direction I have to persue.
Garden knomes BEWARE!
twiz28
- Nov 8, 2004
travel
I didn't put anything on the floor to simulate bumps just flat on the concrete and if compressed nicely, again this was without the track on but I can't see it making a big difference. I had the cams set at 2 and 4, never tried it anywhere else.
stoutner
- Dec 6, 2005
- Seneca Falls, NY
- www.ecsexpress.com
There is a good chance I'll be trying mine out this weekend. Might be heading up to Quebec to give it a little shake down.
Shane
- Dec 21, 2004
- Niskayuna, NY
- www.fa.ml.com
- 2014 YAMAHA VIPER LTX SE
2015 Ski-Doo 800 XRS Renegade
2012 Ski-Doo 600 ace
2010 Ski-Doo 600 e-tec GTX Limited
2007 Polaris Dragon 120
stoutner said:There is a good chance I'll be trying mine out this weekend. Might be heading up to Quebec to give it a little shake down.
Me too stoutner! Where are you going?
Maybe we can meet up and compare notes etc. It would be cool to test and tune together.
