Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I'm with ya. I figured there's no way it could possibly hurt. Thanks for the tips, RichThose actually work.
Make sure you get it tight enough so you have adjustment both ways.
Just carry a 13mm gear wrench with you and it is an easy adjustment.
I left 1 stock strap in the right side at full length for a safety strap.
PS...is 13mm the new 10mm. It's almost a necessity. Suspension, AFPR, etc.
SentSend me a link to that please doc
I have had one of those on my Apex Attak for many years....worked good. Was very effective for a quick suspension adjustment for weight transfer with varying conditions at the snow drags.So I bought one of these knob jobs. In theory you would be able to ride around with your limiter strap on the loose setting and then be able to crank it down on the lake.
Don't worry my budget for useless gadgets is still in the black. Lol.
I'll stick it next to my knockout kit and hurricane intake upgrade. Lol.
Worked for me.
Doc Harley
- Oct 17, 2016
- Here & there
So I turn the adjuster all the way loose, then put it on the sled with the factory hardware. My thought was it should be manageable, then I can crank it tight from there. Hope that makes sense?!?!
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Slick design and do let us know how that works out for you… Maybe a brief product review?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
RN&DHs update -- 155.5
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Pitter patter let’s get at her!
Fast
- Sep 25, 2018
Nice last week they were at 149.8RN&DHs update -- 155.5
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
RN&DH The fastest small turbo 998?
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
Thanks for the great video. Love to see full weight trail sleds at warp speed. Takes lots of engineering, lots of time, lots of cash, and biggins!RN&DH The fastest small turbo 998?
Doc Harley
- Oct 17, 2016
- Here & there
Well, i sent my sled out to get H/Studs & a turbo R&R (DIY Mod Stock) doing my best to join the 120mph club, in 1,000 on hard pack. I think I'll come up a little short lol! Stock 1.25" track & stock primary...Yikes!!
Prayers for a great season for all!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
How much power increase with the turbo?
Doc Harley
- Oct 17, 2016
- Here & there
Tim, this is a DIY mod with all work done at a professional turbo shop. Pure speculation but I suppose when I get out and run it (1,000ft) 2mph would be slightly disappointing, 4mph would be a perfect world. Any more then that and I'd be tickled pink!How much power increase with the turbo?
Of course I'd be running on straight 93. Zero Boostane.
Turboflash
- Mar 18, 2019
- Southern MN
With a stock waste gate, and one of the "store-bought" tunes, remember the ecu is controlling boost (by controlling waste gate and using the tune boost level that it's programmed with). No matter how "good" or big your turbo is, your boost is same. HP improvements come from improvement in charge density, i.e. denser cooler incoming air, and the combined weight of these wheels is 12.5 grams (approx 7%) lighter than stock ones so the turbo spools quicker. When I ran my sled on the same track dyno before and after the turbo mod, to run the same AFR, I had to increase my fuel pressure about 5 lbs.(even at higher ambient air temp). That told me that the incoming air density was higher.
If you have a tune with no ecu boost limit (race map), then the mod stock turbo does produce more boost and therefore more HP.
Doc Harley
- Oct 17, 2016
- Here & there
Mosty agree with your assessment. I feel with lighter wheels, a cooler denser air charge should increase power at any given level.With a stock waste gate, and one of the "store-bought" tunes, remember the ecu is controlling boost (by controlling waste gate and using the tune boost level that it's programmed with). No matter how "good" or big your turbo is, your boost is same. HP improvements come from improvement in charge density, i.e. denser cooler incoming air, and the combined weight of these wheels is 12.5 grams (approx 7%) lighter than stock ones so the turbo spools quicker. When I ran my sled on the same track dyno before and after the turbo mod, to run the same AFR, I had to increase my fuel pressure about 5 lbs.(even at higher ambient air temp). That told me that the incoming air density was higher.
Why do we switch to a high flow muffler? Why do we replace the stock exhaust manifold with a header?
Less restriction = more efficiency. Same applies to the turbo. Shouldnt be a big surprise ro these guys.
Turboflash
- Mar 18, 2019
- Southern MN
You're right on everything!Ego Alert!! Thanks for giving me the credit on finding the wheels & getting you an installer! Some people...lol! Don't you have a thread started somewhere else?!?! Hahaha.
I only did the dyno stuff.
- 11K
