2-3 hp with plugs
87gtNOS said:
It's because it's a colder plug....not the increased compression.
Will the CR10E work the same? i think the K means dual electrode. I have a box of CR10E 's in my garage & hope I can see any gain with them.
BA
BA APEX said:
Will the CR10E work the same? i think the K means doul electrode. I have a box of CR10E 's in my garage & hope I can see any gain with them.
BA
In all honesty, I'd say they would have the same affect.
Maybe i will get a chance to try them this winter. I have 3(i'll get a 4th at the auto store) of the CR10EK 's & a 10 pack of the CR10E 's.
Are these supposed to help on top end too?? I noticed no difference between my top speeds on radar when my sled was cool or when it had SEVERAL consecutive runs and was hot. all runs on ice.
Everyone seems to be on board with the fact that a spark plug can make a difference. If you are still unsure, do this. Get your or your buddies old two smoke out. change out his/hers hopefully NGK spark plugs with the appropriate brand new Champion brand and ride it. Now put back the old oiled up NGK's back it. You will not believe the difference. I've found this to be true on Snowmobile, ATV's, and PWC's. I'm sure there is a reason, I don't know it so I'm not going to try and explain it but I know there is a major difference in power. Anyone else experiance this and have an explaination?
I have NEVER, REPEAT--NEVER, seen any power differances in spark plugs in a two stroke, unless one was fouled. I have dynoed many! The cr-ek series is what work on the four stroke due to the exposed spark, not because their colder, not because there are two sparks. Its because you are exposing the spark to the mixture more efficently. No differant than indexing, which is a proven power adder to high performance four-strokes. Anybody find out if diesel is available yet in the UP?
hey Mike, now that is plausable!! Similar to indexing, which is hard to do in a small 5 valve head.
87gtNOS said:
Sled Dog, are you serious?? Read my posts, LEARN how a spark plug works. The heat from the plug cleans itself????? WTF??
Some educational reading here...isn't that what these forums are for??
http://www.ty4stroke.com/viewtopic.php?t=24774&postdays=0&postorder=asc&start=30
and btw...I don't disagree with them working...but please, understand why they work!! REAL race teams, like NHRA, Nascar, etc, all use heat ranges to fine tune throughout the day.
Yes I am serious. Where did you get the idea that I didnt know the heat cleans the plug please reread my posts. I posted that NGK spark plug info and how it works two years ago.
87gtnos here you do some reading this is right from NGK site on how a plug works.
Spark Plugs Overview
The World Leader
Spark plugs are one of the most misunderstood components of an engine. Numerous questions have surfaced over the years, leaving many people confused.
This guide was designed to assist the technician, hobbyist, or race mechanic in understanding, using, and troubleshooting spark plugs. The information contained in this guide applies to all types of internal combustion engines: two stroke engines, rotary engines, high performance/racing engines and street vehicles.
Spark plugs are the "window" into your engine (your only eyewitness to the combustion chamber), and can be used as a valuable diagnostic tool. Like a patient's thermometer, the spark plug displays symptoms and conditions of the engine's performance. The experienced tuner can analyze these symptoms to track down the root cause of many problems, or to determine air/fuel ratios.
Spark Plug Basics:
The spark plug has two primary functions:
To ignite the air/fuel mixture
To remove heat from the combustion chamber
Click here to download the NGK part number guide
Spark plugs transmit electrical energy that turns fuel into working energy. A sufficient amount of voltage must be supplied by the ignition system to cause it to spark across the spark plug's gap. This is called "Electrical Performance."
The temperature of the spark plug's firing end must be kept low enough to prevent pre-ignition, but high enough to prevent fouling. This is called "Thermal Performance", and is determined by the heat range selected.
It is important to remember that spark plugs do not create heat, they can only remove heat. The spark plug works as a heat exchanger by pulling unwanted thermal energy away from the combustion chamber, and transferring the heat to the engine's cooling system. The heat range is defined as a plug's ability to dissipate heat.
The rate of heat transfer is determined by:
The insulator nose length
Gas volume around the insulator nose
The materials/construction of the center electrode and porcelain insulator
A spark plug's heat range has no relationship to the actual voltage transferred though the spark plug. Rather, the heat range is a measure of the spark plug's ability to remove heat from the combustion chamber. The heat range measurement is determined by several factors; the length of the ceramic center insulator nose and its' ability to absorb and transfer combustion heat, the material composition of the insulator and center electrode material.
Heat rating and heat flow path of NGK Spark Plugs
The insulator nose length is the distance from the firing tip of the insulator to the point where insulator meets the metal shell. Since the insulator tip is the hottest part of the spark plug, the tip temperature is a primary factor in pre-ignition and fouling.
Whether the spark plugs are fitted in a lawnmower, boat, or a race car, the spark plug tip temperature must remain between 500C-850°C. If the tip temperature is lower than 500°C, the insulator area surrounding the center electrode will not be hot enough to burn off carbon and combustion chamber deposits.
These accumulated deposits can result in spark plug fouling leading to misfire. If the tip temperature is higher than 850°C the spark plug will overheat which may cause the ceramic around the center electrode to blister and the electrodes to melt. This may lead to pre-ignition/detonation and expensive engine damage. In identical spark plug types, the difference from one heat range to the next is the ability to remove approximately 70°C to 100°C from the combustion chamber. A projected style spark plug firing tip temperature is increased by 10°C to 20°C.
Tip Temperature and Firing End Appearance
The firing end appearance also depends on the spark plug tip temperature. There are three basic diagnostic criteria for spark plugs: good, fouled and overheated. The borderline between the fouling and optimum operating regions (500&def;C) is called the spark plug self-cleaning temperature. The temperature at this point is where the accumulated carbon and combustion deposits are burned off.
Bearing in mind that the insulator nose length is a determining factor in the heat range of a spark plug, the longer the insulator nose, the less heat is absorbed, and the further the heat must travel into the cylinder head water journals. This means the plug has a higher internal temperature, and is said to be a hot plug. A hot spark plug maintains a higher internal operating temperature to burn off oil and carbon deposits, and has no relationship to spark quality or intensity.
Conversely, a cold spark plug has a shorter insulator nose and absorbs more combustion chamber heat. This heat travels a shorter distance, and allows the plug to operate at a lower internal temperature. A colder heat range is necessary when the engine is modified for performance, subjected to heavy loads, or is run at high rpms for a significant period of time. The colder type removes heat more quickly, and will reduce the chance of pre-ignition/detonation and melting or damage to the firing end. (Engine temperature can affect the spark plug's operating temperature, but not the spark plugs heat range).
Below is a list of some of the possible external influences on a spark plug's operating temperatures. The following symptoms or conditions may have an effect on the actual temperature of the spark plug. The spark plug cannot create these conditions, but it must be able to cope with the levels of heat...if not, the performance will suffer and engine damage can occur.
Air/Fuel Mixtures seriously affect engine performance and spark plug operating temperatures.
Rich air/fuel mixtures cause tip temperature to drop, causing fouling and poor driveability
Lean air/fuel mixtures cause plug tip and cylinder temperature to increase, resulting in pre-ignition, detonation, and possibly serious spark plug and engine damage
It is important to read spark plugs many times during the tuning process to achieve the optimum air/ fuel mixture
Higher Compression Ratios/Forced Induction will elevate spark plug tip and in-cylinder temperatures
Compression can be increased by performing any one of the following modifications:
a) reducing combustion chamber volume (i.e.: domed pistons, smaller chamber heads, mill ing heads, etc.)
b) adding forced induction (Nitrous, Turbocharging or Supercharging)
c) camshaft change
As compression increases, a colder heat range plug, higher fuel octane, and careful attention to igni-tion timing and air/fuel ratios are necessary. Failure to select a colder spark plug can lead to spark plug/engine damage
Advancing Ignition Timing
Advancing ignition timing by 10° causes tip temperature to increase by approx. 70°-100° C
Engine Speed and Load
Increases in firing-end temperature are proportional to engine speed and load. When traveling at a consistent high rate of speed, or carrying/pushing very heavy loads, a colder heat range spark plug should be installed
Ambient Air Temperature
As air temperature falls, air density/air volume becomes greater, resulting in leaner air/fuel mixtures. This creates higher cylinder pressures/temperatures and causes an increase in the spark plug's tip temperature. So, fuel delivery should be increased. As temperature increases, air density decreases, as does intake volume, and fuel delivery should be decreased
Humidity
As humidity increases, air intake volume decreases
Result is lower combustion pressures and temperatures, causing a decrease in the spark plug's tem-perature and a reduction in available power.
Air/fuel mixture should be leaner, depending upon ambient temperature.
Barometric Pressure/Altitude
Also affects the spark plug's tip temperature
The higher the altitude, the lower cylinder pressure becomes. As the cylinder temperature de-creases, so does the plug tip temperature
Many mechanics attempt to "chase" tuning by changing spark plug heat ranges
The real answer is to adjust jetting or air/fuel mixtures in an effort to put more air back into the engine
Types of Abnormal Combustion:
Pre-ignition
Defined as: ignition of the air/fuel mixture before the pre-set ignition timing mark
Caused by hot spots in the combustion chamber...can be caused (or amplified) by over advanced timing, too hot a spark plug, low octane fuel, lean air/fuel mixture, too high compression, or insufficient engine cooling
A change to a higher octane fuel, a colder plug, richer fuel mixture, or lower compression may be in order
You may also need to retard ignition timing, and check vehicle's cooling system
Pre-ignition usually leads to detonation; pre-ignition an detonation are two separate events
Detonation
The spark plug's worst enemy! (Besides fouling)
Can break insulators or break off ground electrodes
Pre-ignition most often leads to detonation
Plug tip temperatures can spike to over 3000°F during the combustion process (in a racing engine)
Most frequently caused by hot spots in the combustion chamber.
Hot spots will allow the air/fuel mixture to pre-ignite. As the piston is being forced upward by mechanical action of the connecting rod, the pre-ignited explosion will try to force the piston downward. If the piston can't go up (because of the force of the premature explosion) and it can't go down (because of the upward mo-tion of the connecting rod), the piston will rattle from side to side. The resulting shock wave causes an audible pinging sound. This is detonation.
Most of the damage than an engine sustains when "detonating" is from excessive heat
The spark plug is damaged by both the elevated temperatures and the accompanying shock wave, or concussion
Misfires
A spark plug is said to have misfired when enough voltage has not been delivered to light off all fuel present in the combustion chamber at the proper moment of the power stroke (a few degrees before top dead center)
A spark plug can deliver a weak spark (or no spark at all) for a variety of reasons...defective coil, too much compression with incorrect plug gap, dry fouled or wet fouled spark plugs, insufficient ignition timing, etc.
Slight misfires can cause a loss of performance for obvious reasons (if fuel is not lit, no energy is be-ing created)
Severe misfires will cause poor fuel economy, poor driveability, and can lead to engine damage
Fouling
Will occur when spark plug tip temperature is insufficient to burn off carbon, fuel, oil or other deposits
Will cause spark to leach to metal shell...no spark across plug gap will cause a misfire
Wet-fouled spark plugs must be changed...spark plugs will not fire
Dry-fouled spark plugs can sometimes be cleaned by bringing engine up to operating temperature
Before changing fouled spark plugs, be sure to eliminate root cause of fouling
Will you guys give up already.....
