snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I am impressed with the goldiggers I now have on this track,yes .3125 thousands may or may not provide enough hook up for this kind of power,only time will tell.Gold diggers with 5/16”penetration Pete.
waldo1
took all mine out on xtx except the 2 in front and 2 large ones in rear - problem solved,,,, o - and duponts.. not sure if id doo that on a 137 or 29
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Here you go Byam!!
Also, went to visit one of my good Buds on Sat who owns a Tcat. He upgraded his rear axle and so graciously donated his old one to me. I cut the spacer and added a 4th wheel.
With all these changes I should gain at least 1 mph!! Lol.
How are the doo idlers holding up? In a another thread you mentioned a doo wheel # with spokes and caps so just though I would bump it up here in case anyone is interested.
17,18 Cats/Winders came with 5.65 inch or 143.5mm wheels.
19/20 Cats/Winders came with 5.5 inch or 139.7mm wheels, but they are junk!!
BRP# 503191316 wheels measure 141mm or 5.5 inches. 1.3mm bigger than 19/20 models, but 2.5 mm smaller than 17/18.
Smaller wheel = less waves in track under slide = faster speed!!
RAMSOMAIR
I have 2 Doo wheels inside up front and are doing real well
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
I still have the center hub wheels with outer fourth wheel kit. Just check bearings every year. So far holding up well.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
better for slider wear!!!!According to their website, it appears JT Racing only makes wheels for the rear axle.
My 17 RTX went 5500 miles without a wheel issue, so I was gonna go with those, but the 19 wheels are a little smaller at 5.5 inches vs 5.63 inches for the 17.
Will going .13 inches bigger be a big deal?
Fleecer
- Jun 13, 2014
- 2019 SRX
Just replaced the bearings in the Doo wheels last week. Put 3300 miles so far, and wheels look/work great!!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Have good results with these. Inside or out.. Don't looks great , BUT
https://www.ebay.com/itm/SKI-DOO-BLACK-PPD-OEM-141MM-IDLER-WHEEL-OEM-503191316-FITS-MOST-REV-AND-XP-08-12/281875383761?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
SledFreak
- Feb 7, 2005
- Ontario. Canada
But, you can put the caps on them? Also, the bearing is the same and is a direct fit? Are they the same size?Have good results with these. Inside or out.. Don't looks great , BUT
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
These are JUST smaller then stock size.(outside diameter). Like JUST.. Don't have sizes off hand, but these last and have a good layer of rubber on them. I run these inside the rails. Same bearing.But, you can put the caps on them? Also, the bearing is the same and is a direct fit? Are they the same size?
not sure of caps
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Ski doo wheels 5.55" Cat 5.63" I believe
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Doo 141mm with caps. Picture is white but the number is for black.
Black, Wheel Assembly 141 mm 503192794
Would match great with these 8" from the 4th wheel kit. Anyone has AC or Yamaha individual part number just for the black wheel with caps?
ssgzag15
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
- You cheap out with the black wheels back there. lol Just kidding, bling bling.
- 12K
