Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
@cannondale27 - just curious. Why did you switch to the new master cylinder? Was it just for the comfort of the brake lever alone, or are there other benefits?
Lever and feel. Hard to say which gives it the one finger feel.@cannondale27 - just curious. Why did you switch to the new master cylinder? Was it just for the comfort of the brake lever alone, or are there other benefits?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I haven't ridden a sled with the new master cylinder - so I can't comment on the feel of the brake (not to be confused with the feel of the lever). But a simple swap to the Polaris brake lever makes a world of difference. The previous style of master cylinder is the same one used on the Polaris Axys chassis. So the brake lever is a direct swap and has a much better feel to it than the long aluminum one used by Yamaha/Cat. I can only assume the lever that comes on the new master cylinder would have the same feel to it.Lever and feel. Hard to say which gives it the one finger feel.
ProbablyI haven't ridden a sled with the new master cylinder - so I can't comment on the feel of the brake (not to be confused with the feel of the lever). But a simple swap to the Polaris brake lever makes a world of difference. The previous style of master cylinder is the same one used on the Polaris Axys chassis. So the brake lever is a direct swap and has a much better feel to it than the long aluminum one used by Yamaha/Cat. I can only assume the lever that comes on the new master cylinder would have the same feel to it.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
On and off trail were this impressive?Its where all Cats/Yamacats need to be body work and control wise. Could pick up back end with one hand. Read my mind it seemed response wise. So easy and dare I say it. Refined.
yesOn and off trail were this impressive?
- 16K
- 28K
