lilrez
- Feb 7, 2016
- Near Ottawa
Ah yes will do.. didnt leak a drop last yearCheck the top of your oil tank to make sure the casting was knocked out with a vent hole. Mine wasn’t and had a slow oil leak. The round part on top that has 4 bolts holding it on. It’s under there. Could probably pull the ROV hose off the top of it and check with a flash light
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
My 2019 was leaking also I.just resealed it with permatex today!! Giving it a full 24hrs to cure before.adding Oil!!
I also got rid of.the roll over valve!!!
trdehmer
- Jan 22, 2019
- Minnesota
- SRX/Sidewinder
Is that oval area supposed to be wide open?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Yeah I already contacted them over a yr ago....first time they asked me if I would send them my tank to help mockup, and when I replied, I never heard back again....and not since, as I have emailed several times.I forget the company but a guy on the FB page mentioned he made oil tanks for the Nytro's and he's making one for the Winder where it bolts in same place but its a self contained tank, which makes a heck of a lot of sense.
Its really too bad, as this would be a huge money maker for someone to build one. Maybe Dave at Hurricane will?! !
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
No that pic is correct...Just that back lower section should be open. There is another post/pic with NO opening there at all.Is that oval area supposed to be wide open?
Ill try to find it.....It was a SRX I believe was posted by Dave.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Ok found it...
CORRECT
INCORRECT - NO CUTOUT HOLE from factory.
CORRECT
trdehmer
- Jan 22, 2019
- Minnesota
- SRX/Sidewinder
Sounds like the dealer just verified that was the issue!!! Thx!
Ok found it...
CORRECT
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
Why not tig the tank to the chaincase cover , no reason to remove it !
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I wouldnt, have you seen all the stuff inside that IMO should be cleaned out once in awhile...
Just another item that convinces me that if I decide to pickup a SW, I will obviously have to get it in the spring so I have all summer long to disassemble the complete sled, correct all the factory issues, and then reassemble by December.
lilrez
- Feb 7, 2016
- Near Ottawa
Its real easy. If you have oil in you intake tube then the hole in your oil tank is cut out lol
