Chris Rose
- Jul 29, 2016
- Powassan ONT
- 2017 sidewinder stx-DX with TD/Max 16 stock muffler
- chrisjrose2018@@gmail.com
Not cat tracks for sure. LolGuys, I was just out riding near the Yamaha test area this afternoon when I came across these tracks. Looks like they're really listening to us and gone after some very significant weight reduction. Rumors are this thing really flies too. Apparently they haven't worked out the steering yet, probably 2021 before it's released.
T-Bone
Does anybody recall how long before the official release we started seeing the teaser vids for the Viper and Sidewinder?
Seems like if there was something other than BNG we should see teasers any time now
Ski-Doo's release date is Feb 18th at 10:10 pm (EST). Thats Monday night. No teaser from them that I'm aware of.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
Looking back to previous patents, what if Yamaha combined the tilting front end with the Cat single rail skid? Could even use the linked shock resi that debuted on the Apex.
whitedust1
What are you wanting a powder sled? The reservoir front end was to keep both skis planted in turns not what a powder rider wants when carving powder. Trail sled the Alpha makes no sense either so again what are you wanting to create?Looking back to previous patents, what if Yamaha combined the tilting front end with the Cat single rail skid? Could even use the linked shock resi that debuted on the Apex.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
The Yamaha patent had a track that tall lugs in the middle that got smaller to the outside edges to allow the front suspension, and sled, to lean into a corner on the trail. The Cat single rail would basically allow the same thing while maintaining lug height across the track. I could see it working well on a powder sled too, especially with the cross talking shocks. Pressure on the inside ski would push the outside ski down, basically a reverse swaybar!What are you wanting a powder sled? The reservoir front end was to keep both skis planted in turns not what a powder rider wants when carving powder. Trail sled the Alpha makes no sense either so again what are you wanting to create?
whitedust1
The alpha does that by design front reservoir shock adds weight wouldn’t be necessary in powder application. Added riser to my Apex xtx draws me forward so front skis stay planted. Although I do like reservoir shocks concept I would like to see eps evolve to new 150-160 hp trail sled.The Yamaha patent had a track that tall lugs in the middle that got smaller to the outside edges to allow the front suspension, and sled, to lean into a corner on the trail. The Cat single rail would basically allow the same thing while maintaining lug height across the track. I could see it working well on a powder sled too, especially with the cross talking shocks. Pressure on the inside ski would push the outside ski down, basically a reverse swaybar!
T-Bone
This thread is about as elusive as spy photos of the 2020 Yamaha sleds
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
Not really. It is just a slightly tweaked version of the chassis that came out in 03. Many parts will interchange from 03 through 18.
Yep thats what makes it new and better
Sasquatch
- Apr 17, 2004
- www.dptc.com
- Yamaha's
Gear-drive, no chain, and employ a planetary gear set to create a reverse gear...?
Ask Cat how that worked out.
Whammerjammer
- Feb 12, 2019
- N. Illinois
- 13 Nytro MTX, IQR, Redline
Ya, but, isn’t there a difference between Arctic cat engineering and Yamaha engineering...?Ask Cat how that worked out.
sideswipe77
- Nov 7, 2014
- Michigan
- 2012 Yamaha apex se
2011 Yamaha apex se
How much extra would you guys pay for a 50 lb lighter Sidewinder or anything of that size or Apex. Or a hundred pounds lighter?
Clyder6R
- Dec 24, 2015
- Atlantic Canada
- 2015 Yamaha Viper MTX 153 McXpress 190 kit
Anyone see the other leak for arctic cat? C tech 9000. Supposedly the 880cc motor i was talking about earlier in this thread. I wonder if it is true and yammi built like i was told.
Maybe yamaha is supplying all the motors for cat??
whitedust1
It would have to have eps and skis that turn more interested in Apex replacement at 150 to 160 hp. The usual usd of $12k with incentives would be doable. Price increase for the big dog SW.How much extra would you guys pay for a 50 lb lighter Sidewinder or anything of that size or Apex. Or a hundred pounds lighter?
WillowAce
- Jan 21, 2017
- Northern Wisconsin
- 2016 Viper L-TX-DX - Sold
2019 Switchback XCR - Sold
2015 Viper L-TX-LE
2019 Renegade 850 - In the shed just in case
2020 Viper L-TX-SE
Good question. Yamaha has a 2 stroke 600 already in the European market and has the Ctech motor under the hood. Bigger question is why they designated it the 9000? Wasn't that reserved for the 998 turbo?Anyone see the other leak for arctic cat? C tech 9000. Supposedly the 880cc motor i was talking about earlier in this thread. I wonder if it is true and yammi built like i was told.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
- Status
