swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Which location is your 137" skid mounted ? Rear has 2 choices. Front has 3. Thanks for your participation.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Rear is on lower hole, front is hole most towards the rear.
How many miles you have on?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Big fat ZERO, maybe a 1/2 mile at best. A short 100 ft. from the truck to the garage.How many miles you have on?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
I feel better now, thats where mine are.Rear is on lower hole, front is hole most towards the rear.
After about 200 miles check you air box and pull of the cover. I find every few hundred miles you need to clean out the oil mist or it will leak out but the clutches. I think the rollover valve vent need to find a new home. Maybe out under the sled.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Thanks, but Fabio beat you to it. Already did that reroute. Great bunch of MotorHeads here. THANKS.After about 200 miles check you air box and pull of the cover. I find every few hundred miles you need to clean out the oil mist or it will leak out but the clutches. I think the rollover valve vent need to find a new home. Maybe out under the sled.
How did he route it? Leave rollover just routed out the hose?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
My dealer told me to keep the oil level near the low line to stop venting that crap. I did and have very little residue .I was worried if it’s vented some where cold it could freeze up with the moisture and pop the seal anyway. Fabio said his started leaking. Makes me wonder
I had mine at half maybe I can try dropping to the line. Right now it still makes a mess.
hellflyer
- Dec 2, 2008
I did a 900km ride last week and had very little residue when I put it away yesterday for the season.
so oil level on the line?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Yes MrSled I just ran the hose to the bottom of the belly pan, between 0 to 780km my sled had oil everywhere on the left side due to the oil coming out of the air box, not sure why I had so much but I did.
My oil has been about half way between the lines since I did the first oil change at 780km, and last week noticed a slight film on the lower bolt of the oil tank. I also don’t see the black gasket sealant popping out where it’s leaking like I do around the rest of the case.
thank you. I know the stock factory seal on the tanks is just a matter of time before they leak.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
How I found out about the oil going into the air box was I had the sled running with the side panel off and heard something rattling in the air box, when I opened the air box there was a good amount of frozen oily sludge rattling around. Since than I removed the hose from air box.
