Fox 2
Racy2
- Mar 16, 2005
- Toronto, Ontario
- 2022 Sidewinder SRX LE
Thanks, looks like they may be sending sleds according to when they were ordered. Hoping that is the case as I ordered mine the second day of the spring checkI don’t remember the exact date , but I was the first one and ordered the day spring break was announced, This is the only one my dealer has gotten so far .
gamemaster
Port Yamaha posted a picture of the srx. It looks like yours are upside down. Look here:Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
SnowRipper
- Mar 15, 2021
- Ottawa Ontario
- 2022 SRX
- Ottawa
So your sticker is on backwards? How come some are and some aren’t. In this pic it looks rightLooks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Well
Maybe you have a limited special collectors edition. One of kind. Should be worth and additional 5k don’t ya think. Looks like a nice sled though !Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Reservoir is suppose to be on bottom!!%100
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
Your dealer is correct..I can see why too,my guess is the clearance would be to close because the a arm's sit higher.
Fox 2
He has a call into the rep . If you switch them it looks like the electrical connectors will rub on the charge tubes . I am going to change them around when I get time and see .Your dealer is correct..I can see why too,my guess is the clearance would be to close because the a arm's sit higher.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Is the iqs sticker on the end of the actuator facing upright ?Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
are the shocks on the wrong side ?Is the iqs sticker on the end of the actuator facing upright ?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have never had a Yamaha blue sled .are the shocks on the wrong side ?
I have the 22 SRX coming because I love the colours , and a LTX GT EPS because of the EPS .
I am not sure which one I keep , but the actual delivery date may be the deciding factor , as I hear the EPS sleds are coming very late , as in after my first planned trips north.
Only time will tell .
RAMSOMAIR
JMS@Yamaha
Hi Fox,
Great looking sled!
It appears the shocks are on the wrong sides, (Example Left is on Right, and Right is on Left).
Great looking sled!
Fox 2
Yes they are , everyone that sees it loves it , even non sledders , I will change around , I thought maybe the new wiring connector would be to close to the tube . But not . ThanksHi Fox,
Great looking sled!
