hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Not tuned or studded, but just surpassed 4,000 miles on my original belt last night!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Haha, Trav you are cheating with no tune! lolNot tuned or studded, but just surpassed 4,000 miles on my original belt last night!
Dan
Arc21981
- Jan 31, 2019
- Portland,Maine
- 2018 Sidewinder xtx se 137"
Completely stock 18 xtx 137" blew belt 8jp 2 weeks ago in Moosehead with 420 mi. on it. Got about 500 mi. now on cheapo gates 8dn equivalent had to add a couple washers to get belt back up in secondary but that's the only thing I changed.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
3600 kms on Ultimax xs825 running 240/270/290 Hurricane 21/41 gear lots of high speed runs. The last 1500 kms with 22/41 The last 2 rides Been very hard on it using 290 hp trying to break and still looks mint. I’m convinced with my setup is good.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Haha haha love it!!!! Your probably the only one on this site trying to break a belt and not succeeding!!! I rode with hammer and he rides HARD.3600 kms on Ultimax xs825 running 240/270/290 Hurricane 21/41 gear lots of high speed runs. The last 1500 kms with 22/41 The last 2 rides Been very hard on it using 290 hp trying to break and still looks mint. I’m convinced with my setup is good.
your set up has been flawless!!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Need details!! I can break them almost on command!
Helix?
Springs?
Wrap?
Weights?
Offset?!
Thanks in advance!!!
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
My riding buddy with the 850 Backcountry was sure he would win a drag race with the Winder. LOL Zip codes different. I sent him a post card. "Whoa I really underestimated that sled."
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Helix?
Springs?
Wrap?
Weights?
Offset?!
Yep, the lowered offset and Ultimax works amazing for me too....I believe it is the belt mostly and offset for me.
I also run a lower helix this season(37/35) so less slippage. 39/35 was good too but this yr is best for clean sheaves,no slip.
I through so many diff secondary spring setups at this sled this season, went from cold to HOT, and still didnt hurt the belt. But b/o at 6/2 is overall best for TRAIL riding hard. The heavier springs and wraps just made more heat, they did not help my engine braking much at all which was my goal, as I believe the EBRS kicks in to overcome anything i do in the secondary.
DTYA-1@ 77.3g, TP Rollers up front, and HT rollers in secondary make for smooth action and bushings all look good on the TP at 6000kms now. Now with 3500kms on the belt(this seasons mileage so far) looks great and has ZERO belt dust, so Ill never run any other belt.
I also run the red primary spring up front(less then most here).
58mm offset with a custom washer to allow only 1mm of float with my BOP adjuster. Also added new grease to the secondary shaft mid season and it sure goes a long way to allowing float action on stand. Gets all that rust off shaft.
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Helix?
Springs?
Wrap?
Weights?
Offset?!
Try running Action Jacks set up and see how it works out for ya.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Stock muffler TD Jukebox
266mm and 62.5 offset - never adjusted
TD Clutching
Dalton Black teal primary spring
DTYA-1 empty
Dakton Black orange gen 1 at 70
factory 35 helix
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
Pretty much all the same as yours other than I have 0 float and 41/35 helix also I have 22/41 gear now I’m trying and my results are same as Dans.Yep, the lowered offset and Ultimax works amazing for me too....I believe it is the belt mostly and offset for me.
Dan
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
That is impressive with that junk stock belt for sure! Wonderful!
Why do you call the 8JP junk? Lol
I get great performance, good life for not a lot of doh ! Like 75% of the cheapest aftermarket around.
Actually never had any issues with any Mitsuboshi built belt, hell even BRP belts were warrantied when they got em made in Japan.
ronzx9
- Jan 11, 2017
- Ohio
- 2017 Sidewinder L-TX-LE, 2016 Grand Touring SE 1200
I have a total of 1950 miles on the ultramax. Running Hurricane 225-240-270. 37/35 helix dalton blk/org. Belt still looks good. I thought I was getting a bunch of belt dust but it ended up being brake dust. This is all after setting offset with the hurricane tool. If you go by the speedo I have over 4000 miles nut 2000 of them are from a speed sensor failure in the middle of a saddle bag trip. 261mph for 2 days straight.
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
What wrap do you have your BO at? What offset?
Thanks!
ronzx9
- Jan 11, 2017
- Ohio
I don't remember for sure. Whatever the instructions said and I bought it this winter. I wanna say 6-1 or 6-2.
Didn't measure the offset other than using the hurricane alignment tool. my clutches are never too hot to touch. In the past there was enough heat inside the cover to crack all the graphics. I did add a piece of drier exhaust hose and ran it from the front vent down into the area of the primary to increase cooling.
- 11K
