krm
- Apr 22, 2016
- ny
i wish we had some cold and snow so i could get testing .
try a dayco xtx 44.5 " by 1.415" belt wps #220-35033 8jps are only 1.359 " wide
measure it first ...Nice ....you might get 15 thou belt clearance...wider is better....longer belt will pull rpm down..shift harder...if you felt it was over overrevving this will be good..
It will be hard to feel with so much HP.
You may feel it more if you run 1/2 to 3/4 speed and compare
I am probably going to machine my clutches to fit the longest of the Doo race belts... 1.5 wide about that same length. I will leave that on 100% and work with the clutches,
Ran a much longer belt on 99 sled..did the above...cool running
gtrdan24
- Nov 28, 2016
- lehigh valley pa
- 2017 Yamaha Sidewinder Btx 153 Le
I wonder if any of these companies will be offering a snorkel intake that comes outside the chassis and pulls cold air with one of them filters with the outerwears pre filter on it?I did a removal of the air filter and made a short pass to see what it felt like.
Definitely could use an open filter element....but need to watch afr's
They willI wonder if any of these companies will be offering a snorkel intake that comes outside the chassis and pulls cold air with one of them filters with the outerwears pre filter on it?
- Apr 14, 2003
- Hessel, Michigan
In the works
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I surely would like to! BUT my ecu is not with me at this time. The muffler runs a little lean with hard pulls. I was told for what its worth "long hard pulls - run at your own risk" Only if I had my ECU? When you testing again?My challenge is to have others that live close to me with a SW that want to try out either one or both of these kits.
Currently working on a members clutch setup now.... Hoping he may want to bring his sled and try these setups on the same test path? I know he's watching this post
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
O wait I dont have any clutches either!I surely would like to! BUT my ecu is not with me at this time. The muffler runs a little lean with hard pulls. I was told for what its worth "long hard pulls - run at your own risk" Only if I had my ECU? When you testing again?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Yep saw your clutches. So did Terry's kitten. Then she stuck her paw inside the splined portion of the secondary. White foot was no longer white about 1 1/2" of it anyway. Have you ever tried to wash a cats foot when they have claws and don't like water. Good thing for Dawn dish soap. It was funny , Terry was not impressed. That cat is like Curious George. lolO wait I dont have any clutches either!
- Apr 14, 2003
- Hessel, Michigan
LOL! I have your clutches so I can install them.
Thinking Sunday for testing
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Sounds like a Cat/Yamaha relationship. Hey maybe we are on to something !!!Yep saw your clutches. So did Terry's kitten. Then she stuck her paw inside the splined portion of the secondary. White foot was no longer white about 1 1/2" of it anyway. Have you ever tried to wash a cats foot when they have claws and don't like water. Good thing for Dawn dish soap. It was funny , Terry was not impressed. That cat is like Curious George. lol
- Apr 14, 2003
- Hessel, Michigan
Hahahahaha!!!!!Sounds like a Cat/Yamaha relationship. Hey maybe we are on to something !!!
That's how my shocks get tested! Vid somewhere.Sounds like a Cat/Yamaha relationship. Hey maybe we are on to something !!!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I knew it you all are in bed with cat all the time.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Please keep your cat away from the Sidewinder. It's bad enough Cat built the thing. Snakes=good Cats=badYep saw your clutches. So did Terry's kitten. Then she stuck her paw inside the splined portion of the secondary. White foot was no longer white about 1 1/2" of it anyway. Have you ever tried to wash a cats foot when they have claws and don't like water. Good thing for Dawn dish soap. It was funny , Terry was not impressed. That cat is like Curious George. lol
