Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
Took my nytro out today to try it out and once it’s about 4500 rpm it runs bad and will not increase rpm at all, has good compression. When this happens the afr Gauge starts reading very lean. Any info? Thanks
Riley Cloarec
- Mar 22, 2018
- Bc
- Nytro mcx270
Check fuel filter pickup etc. Check fuel pressure. If those don't fix maybe injectors.
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
I have changed fuel filter, I’m leaning towards a fuel pressure issue now, it runs very well idling but once it starts making boost it just cuts out and stumbles but doesn’t dieCheck fuel filter pickup etc. Check fuel pressure. If those don't fix maybe injectors.
Riley Cloarec
- Mar 22, 2018
- Bc
- Nytro mcx270
Not sure how the alpine works does it use extra injectors? If so maybe the boost vacume lines need to be checked make sure its sending boost signal to boost controller to turn on injectors.
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
It does run extra injectors and I checked all the lines I could find and didn’t have any cracks or leaks that I could findNot sure how the alpine works does it use extra injectors? If so maybe the boost vacume lines need to be checked make sure its sending boost signal to boost controller to turn on injectors.
Riley Cloarec
- Mar 22, 2018
- Bc
- Nytro mcx270
Could be your regulator not rising as it boosts ?
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
Where would this be, I’m new to this sled and I have had nothing but problems trying to get it going for winter lolCould be your regulator not rising as it boosts ?
Riley Cloarec
- Mar 22, 2018
- Bc
- Nytro mcx270
Does it run external fuel pump and regulator or just stock fuel pump. 240 and down can run off stock pump. 270 up is external. Mine is mcx and sits in front of intercooler
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
I believe it has a external pump under intercooler, it’s a 270 kit so I would think it has one and am pretty sure it does.[/QUOTE]
Riley Cloarec
- Mar 22, 2018
- Bc
- Nytro mcx270
Yea so you'll have a rising rate fuel pressure regulator. Google malpassi rising rate regulator to see what it looks like. It runs a boost line to it so when it sees boost it sends more fuel for extra injectors.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I would suspect the Hobbs switch that turns on under boost. First check fuse for your external pump tho.
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
I’m sorry I am new to this sled, what is a Hobbs switch, also I have just noticed that my primary clutch has some big grooves in it. Could this be causing the sled to possibly redline? And for the tach not to register as it climbs to quicklyI would suspect the Hobbs switch that turns on under boost. First check fuse for your external pump tho.
OZ_8721
- May 11, 2018
- Richland, WA
- Nytro MTX
Bottom line is sled is losing fuel. I'm not familiar with the Alpine kits but you need to check the external fuel pump, regulator, etc and make sure each is working. Renting a fuel pressure gauge from the local auto parts store will help a lot.
I had this same problem with my MCX 270 all last winter, the secondary injectors weren't firing. Finally turned to be either a bad chassis ground for the MCX fuel controller or a bad ground at the extra injectors. I'm leaning toward chassis ground in my situation because I had to replace the steering gate with a used one at the beginning of the season (thats where the chassis ground for the controller goes) and it didn't work after that. The bad ground also ruined (I suspect) my fuel controller because I sent it on to be checked and it was bad. So I had a problem on top of a problem.
Boostednytro09
- Oct 30, 2020
- Castlegar
- Yamaha nytro
I tore into it a bit more and found that the secondary injectors are not firing at all, fuel pressure is good, it has power to the injectors but they aren’t firing, do injectors get stuck closed? The sled sat with fuel in it for a couple years maybe they are clogged?
Mountaintech
What controls the injectors? Not familiar with the Alpine system.
