Bottom line is sled is losing fuel. I'm not familiar with the Alpine kits but you need to check the external fuel pump, regulator, etc and make sure each is working. Renting a fuel pressure gauge from the local auto parts store will help a lot.
I had this same problem with my MCX 270 all last winter, the secondary injectors weren't firing. Finally turned to be either a bad chassis ground for the MCX fuel controller or a bad ground at the extra injectors. I'm leaning toward chassis ground in my situation because I had to replace the steering gate with a used one at the beginning of the season (thats where the chassis ground for the controller goes) and it didn't work after that. The bad ground also ruined (I suspect) my fuel controller because I sent it on to be checked and it was bad. So I had a problem on top of a problem.
