This is obviously correct but the fact remains 7- 10% overdrive increases the belt speed proportionately and with an engine speed of 8800+ creating jackshaft speeds in excess of 9400+ RPM any belt is definitely in the red zone if made to spin at the resultant RPM for any length of time. I used to spin belts that fast in my high RPM Mod snow drag sleds but that was only for 500' - 660'.
Belt rotational speed is also directly related to belt length on the same primary and secondary setup.
For an example the VMAX4s had an ultra long drive belt [52.5"] so when the jackshaft speeds on mod sleds were 9700++ the actual belt rpm was rotating slower then they would on a shorter belt like our Winders have.
Speed is math...
Just to set the record straight on this. The belt speed goes up with OD for sure yes, but in OD its the jackshaft speed that is turning faster than the crankshaft, not the belt.
Speed is math...
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Speed is math...
Right, the belt rotational speed is down with longer belts but the FPS they run is still the same, they just make less rotations around the clutches for the same distance traveled essentially.
Wouldn't it be terrific if these new sleds ran long belts like that with a cushioned drive gear reduction high RPM four cylinder again? Now theres an idea. LOL!!
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Can't wait for some feedback on this , are you going to have a chance to try this this year?
Many of our customers have changed over to the Apex style (previous Yamaha) and are extremely happy with no issues. Everything from the sidewinder clutch will go in to the previous style clutch....only thing you have to do is add 3-4 grams of weight to your setup when changing over.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Are the rollers lasting in the Apex clutches?Many of our customers have changed over to the Apex style (previous Yamaha) and are extremely happy with no issues. Everything from the sidewinder clutch will go in to the previous style clutch....only thing you have to do is add 3-4 grams of weight to your setup when changing over.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Yes they are
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Why???They are not different, are they?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
It's the weight and roller location circle that is different between the clutches. The Sidewinder has a larger circle to put more pressure or swing from the weights which puts more belt squeeze. But I am thinking putting more swing from the weights is playing havoc on the rollers. This is why we are seeing the heavy flatter weights taking rollers out sooner than other less gram weights.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Apex had 9 tooth 2.52 drivers vs the winders 9 tooth 2.86 drivers. 13.5% larger on the winder.
2.52 pitch is taller gearing i thought vs 2.86.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
9x 2,52=22.68
10x 2,52=25,2
11x 2,52=27,72
SW 9X2,86=25,74
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
So I find an Apex clutch, transfer my weights etc over, add 3-4 grams and good to go? Can I still use stock length belt? (Ultimax XS825 is what I use now)
Same primary spring?
Is the Apex clutch quieter? That would be a bonus.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Yes, you will be good to go.
Yes, same primary spring.
The Apex clutch will still have harmonics noise as it is the crank snub shaft...not so much the clutch. But the Apex style clutch has the extra set screws to lock the roller pins from moving and wearing. Or you can put plastic or rubber o-rings to keep the roller pin from moving also.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
The apex rollers are larger. I run the larger 15.5mm rollers on my sidewinder that I took off a used viper clutch. I now have 5000kms on the rollers and bushings are still good. They were used to begin with as well, so not sure on the total amount of kms currently.
Fast
- Sep 25, 2018
Do sidewinders have the set screws tooYes, you will be good to go.
Mine doesn't. Set screws for the weight pins, but not for the roller pins.Sidewinders have the set screws too
Note - I remember many years ago observing Iantomassi's pro-stock Vmax4. They only used the set screws to hold the pins for weights and rollers - no bolts at all!
The Winder primary clutch does not have set screws holding the roller pins in place so the pins can rattle back and forth in the spider.
The Apex primary has set screws to secure both the weight pins and the roller pins so there will be a little less rattle from the Apex primary on the Sidewinder...probably not a huge difference though.
- 12K
