87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Tom, that is too clean. Someone must have cleaned it up. Or that is not prior to 'autotune'?
Thats just a clean map for an Apex... you want to see a SC Charge Map with the Autotune tables filled?
87gtNOS
- Nov 30, 2005
- Toronto
yes, I'd like to see the mess the autotune creates! LOL
87gtNOS
- Nov 30, 2005
- Toronto
yes, thank you Tom. Look at the numbers it pulls!! My Harley does that stuff too!
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
I have my head ported and added 3 degrees timing key on my 07 Apex. I also have an exhaust and a raim air lid for my stock airbox. I have been using one of those fuel accelerators by Hauck, do you think there is an advantage to using the PCV with auto tune for my setup? Would I get some noticible gains? I was also thinking about adding the timing box as well. I would like to get the most out of my setup, but not 1000 bucks for 1 HP LOL
Yamaharider74
- Dec 23, 2013
- theodore,saskatchewan
- 07 Yamaha apex
hello how many pounds of boost is this map set up forHere is an apex PCV map.
10 to 12 lbs.. it has been changed since posted.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
Okay thanks I was curious I have the pcv from hurricane and was just comparing The map I had got with mine was going to try this one out and see how it worked did you change much in yours mine is 12 pounds pulls pretty awsome10 to 12 lbs.. it has been changed since posted.
I added that module from Hurricane to make it run better on the trial.. now thats fixed and I need to re-tune the bottom end. Post up your map, I would like to try yours out please.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
th
you got that voltage clamp ?i found that worked pretty good on mine got that from dave alsoI added that module from Hurricane to make it run better on the trial.. now thats fixed and I need to re-tune the bottom end. Post up your map, I would like to try yours out please.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
here is map for sc apex
Awesome thanks.
Yamaharider74
- Dec 23, 2013
- 07 Yamaha apex
do you have a recent map that works nice on your apex what size of injectors are you runningAwesome thanks.
Im not happy with mine yet. Mine has stock injectors.
