Understood.I took it in on the premises of not running. Gave nothing for it. Trying to figure out if it's worth it getting it going
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Probably worth more on a part out.
It depends. I am confused as to whether it’s actually the engine block that’s damaged or just the starter case. That’s more common and has been seen many times with stuck solenoid or even key stuck on. Takes out starter,one way and could even take out flywheel and stator locking motor up. I want to see a picture.Probably worth more on a part out.
Snake61047
Snake61047
Well that didn't work. Posting to Instagram.
Snake61047
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Down sizing photos is in the frequently asked questions at the top of forum in site help.
Go check it out.
Go check it out.
Snake61047
I managed to get two up without even looking at it lolDown sizing photos is in the frequently asked questions at the top of forum in site help.
Go check it out.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
They wont open up for me.
Snake61047
Well son of a. I put them in my album.They wont open up for me.
i can see 2 of them.
i think you should pull the motor as it might be easyer to see how much damage there is. might be lucky and flywheel might be jamed with stuff but i suspect more is wrong.
Snake61047
I pulled the cover for the starter. Still doing the same thing with the cover off
X2 thats alot of material to go into motor. I bet its everywhere so best is to pull motor and locate it all. That sucksi can see 2 of them.
Snake61047
What would cause that to happen? A rod let go? Why would the case blow out like that
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
This is what I get when I click on the link for his pictures.
- 146K
