thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
you should offer a bundle with the inner plates (Saver kit) and the shaft and I am in.
Thats Dang good thinking Travis! One of those why didnt I think of that things. So simple! Great job!
bleedyamaha
- Sep 28, 2013
- Northern Iowa
X2 small powder coated black plateyou should offer a bundle with the inner plates (Saver kit) and the shaft and I am in.
RtxViper
- Feb 24, 2007
- Deerfield, Wisconsin
- 2019 SRX LE
Probably a dumb question but does anyone know if the srx comes with the rr shaft?
Dan what is the coolant hose fix?Ok I see, great pics.....I was just looking at fiche and makes more sense. So the suspension ears go over the outer bushing, not the shaft itself.
I think your design will do well then....I think you should combo this kit with the coolant hose fix! Everyone should get these and do it all in same install.
Fiche pic....
Thx
34pontiac
- Nov 16, 2014
- WI
- Sidewinder
Apex
Thx
https://ty4stroke.com/threads/exchanger-coolant-leak-fixed-fuel-tank-battery-removal.150907/
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Travis is working on a solution to help with the problem some had, where the small rubber coolant hose, up in top/front of tunnel, that connects the front exchanger to the top/right coolant runner to the rear of tunnel......Where some had ice chunks push upward on tunnel and rip/tear and even pull off the hose clamp connection. I think it will be some sort of shroud.Dan what is the coolant hose fix?
Thx
I know I looked at mine, and was leaning toward a shroud that simply extends forward off the coolant runner, and covers that vulnerable hose. My dealer ran some sliders, connected to the bottom of each coolant runner for extra stud protection, and he ran them longer toward the front which covered this hose, so something like this should work well to help protect it from ice chunks that some guys had issues with.
I know those guys showed their tunnel was bent up above that hose, which is basically directly underneath the header, so I was thinking a strong bracket across top of tunnel(under header) would also be good idea to stop ice chunks from jamming up in there bending the tunnel up which allows hose to be ripped off connection.
Bottom line, really try to get ice chunks out before riding off at speed.
Will be nice for Travis to offer these items together as I believe dropping skid down, will be needed to do both the hose protection AND the heavier RR style front cross shaft.
Dan
marathon mike
I’m in for this
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
So my cross shaft was slightly bent on my sidewinder when I removed it, and I suspect to the surprise of many they will find it bent on their sled as well. With the help of a hammer, I was still able to slide my saver sleeve over top of the bent aluminum shaft. Its nice to know the sleeve can still work even with a slightly bent shaft.
If someone has a broken or severely damaged shaft I will have a few new std cross shafts available to sell.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
delete
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Hi Travis - how soon will you be offering your "shaft saver"?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I posted all my parts in my build thread.....But dont want to take away from Travis very nice design he has.
Dan
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
The shaft savers are made and I plan to get them to powdercoater tomorrow. Should have them back next week.
The tunnel saver plates might be done next week also. Waiting on the right side plates. Turned out I have to make a left and right because rivet locations were not identical on both sides.
Turbo 998
- Mar 30, 2016
- LeSueur MN
- 2017 Yamaha Sidewinder LTX LE, 2014 Yamaha Viper LTX, 2001 Arctic Cat ZR800, 2- Yamaha SS440, Yamaha Enticer 250, Scorpion lil whip, Scorpion Super Stinger
- yes
Awesome when they're done I'll take two black set!!The shaft savers are made and I plan to get them to powdercoater tomorrow. Should have them back next week.
scooterwj
- Dec 4, 2008
- Hell, Michigan
- 2018 SW
Excellent! Can you contact me once these kits are ready to ship and I'll get one. Thank you
- 41K
- 48K
